When I try to start seafile on docker I run into following problem:
*** Running /etc/my_init.d/10_syslog-ng.init...
[2019-05-05T20:36:23.066505] Error opening control socket, bind() failed; socket='/var/lib/syslog-ng/syslog-ng.ctl', error='Permission denied (13)'
Error parsing source, source plugin unix-dgram not found in /etc/syslog-ng/syslog-ng.conf at line 20, column 8:
unix-dgram("/dev/log");
the command I used to start it:
docker run -d --name seafile -e SEAFILE_SERVER_HOSTNAME=seafile.example.com -p 80:80 seafileltd/seafile:latest
Any ideas?
