Hello, I have several problems with LDAP synchronization and roles / department, Everything worked before…
Right now only the ELEVE category is OK
The rest is very random, where there is no quota displayed or a 5GB quota which is not yet defined anywhere (default quota force at 40Bg in seafile.conf but same result)!
The default category doesn’t work either.
The ./seafile-server-latest/pro/pro.py ldapsync command works well and modifies the role in function of the LDAP field
Same result with seafile pro 7.1.3 or 7.1.4
Do you have an idea ?
Thanks
seahub settings
cat seahub_settings.py
ENABLED_ROLE_PERMISSIONS = {
'default': {
'can_add_repo': True,
'can_add_group': True,
'can_view_org': True,
'can_use_global_address_book': True,
'can_generate_share_link': True,
'can_generate_upload_link': True,
'can_invite_guest': False,
'can_connect_with_android_clients': True,
'can_connect_with_ios_clients': True,
'can_connect_with_desktop_clients': True,
'role_quota': '1g',
'guest': {
'can_add_repo': False,
'can_add_group': False,
'can_view_org': False,
'can_use_global_address_book': False,
'can_generate_share_link': False,
'can_generate_upload_link': False,
'can_connect_with_android_clients': False,
'can_connect_with_ios_clients': False,
'can_connect_with_desktop_clients': False,
'role_quota': '1g',
'ADMIN': {
'can_invite_guest': True,
'role_quota': '60g',
'ELEVE': {
'role_quota': '10g',
'SMS': {
'role_quota': '80g',
'SPIN': {
'CIS': {
'FAYOL': {
'CMP-GC': {
custom functions
#coding=utf-8
import sys
reload(sys)
sys.setdefaultencoding('utf8')
def ldap_role_mapping(role):
if 'ADMIN' in role:
return 'ADMIN'
if 'ELEVE' in role:
return 'ELEVE'
if 'SMS' in role:
return 'SMS'
if 'SPIN' in role:
return 'SPIN'
if 'CIS' in role:
return 'CIS'
if 'FAYOL' in role:
return 'FAYOL'
if 'CMP-GC' in role:
return 'CMP-GC'
[/details]
