In windows SeaDrive provide right-click menu with Seafile actions on SeaDrive files, but in Linux this is missing at now.
This can be done as KDE Service Menu actions plugin, here is example of same menu for Dropbox https://store.kde.org/p/998468/
Here https://store.kde.org/p/998135/ I have found plugin for Seafile files, can we add support for SeaDrive files too?
The GUI is still new for Linux. Cool that you found something for KDE, but I think they won’t do it. But even if SeaDrive is closed source, it should be possible to create it yourself if you know what extensions you want to have.
I lookup to code of this script and seems adding support for SeaDrive will not so hard.
In seafile_service_menu.sh
file there are function:
# readSeafileCfg
function readSeafileCfg {
(($DEBUG == 1)) && echo "Reading Seafile configuration..."
SEAFILECONFIGURATIONFILE="$SEAFILE_DIR/.seafile-data/accounts.db"
if [ -f "$SEAFILECONFIGURATIONFILE" ]; then
# Leemos la configuración.
SEAFILE_TOKEN=""
SEAFILE_URL=""
SEAFILE_USER=""
DATA=`sqlite3 "$SEAFILECONFIGURATIONFILE" "SELECT url, username, token FROM Accounts LIMIT 1"`
arr=$(echo $DATA | tr "|" "\n")
for VAL in $arr; do
if [ -z $SEAFILE_URL ]; then
SEAFILE_URL="$VAL"
continue
fi
if [ -z $SEAFILE_USER ]; then
SEAFILE_USER="$VAL"
continue
fi
if [ -z $SEAFILE_TOKEN ]; then
SEAFILE_TOKEN="$VAL"
continue
fi
done
else
print "ERROR: Seafile configuration file not found. Are you sure this is your Seafile folder?"
exit 1
fi
that reads access tokens from Seafile Client sqlite database. I see that SeaDrive have same sqlite file structure, so seems simple path change from:
to
SEAFILECONFIGURATIONFILE="$USER_HOME/.seadrive/accounts.db"
must help! I will try to test this way.
