Just upgraded a Seafile Pro installation to 9.0.7. I can’t access public libraries anymore. Here’s the error
août 11 19:19:16 seafile python[43623]: 2022-08-11 17:19:16,186 [ERROR] django.request:230 log_response Internal Server Error: /published/public/
File "/opt/seafile/seafile-server/seahub/thirdpart/django/core/handlers/exception.py", line 47, in inner
File "/opt/seafile/seafile-server/seahub/thirdpart/django/core/handlers/base.py", line 181, in _get_response
File "/opt/seafile/seafile-server/seahub/seahub/wiki/views.py", line 233, in slug
"has_index": has_index,
File "/opt/seafile/seafile-server/seahub/thirdpart/django/shortcuts.py", line 19, in render
content = loader.render_to_string(template_name, context, request, using=using)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/loader.py", line 62, in render_to_string
return template.render(context, request)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/backends/django.py", line 61, in render
return self.template.render(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/base.py", line 170, in render
return self._render(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/base.py", line 162, in _render
return self.nodelist.render(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/base.py", line 938, in render
bit = node.render_annotated(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/base.py", line 905, in render_annotated
return self.render(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/loader_tags.py", line 150, in render
return compiled_parent._render(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/loader_tags.py", line 62, in render
result = block.nodelist.render(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/defaulttags.py", line 315, in render
return nodelist.render(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/base.py", line 988, in render
output = self.filter_expression.resolve(context)
File "/opt/seafile/seafile-server/seahub/thirdpart/django/template/base.py", line 698, in resolve
new_obj = func(obj, *arg_vals)
File "/opt/seafile/seafile-server/seahub/seahub/base/templatetags/seahub_tags.py", line 315, in translate_seahub_time_str
if now < val:
TypeError: '<' not supported between instances of 'datetime.datetime' and 'int'
