Published library left panel issue
I’m on pro 7.11.
I published a library but it shows weird content on the left panel
This text is contained in one of the files located at the root of the library (normal text)
The left panel should display the list of *md files instead
I deleted /tmp folder, unpublished/published the library, restarted seafile, apache and memcached, without sucess…
Would you have any idea ? Is there any cache somewhere ?
Regards
Well,
I found the reason.
One of my *md files was named index.md
Seafile needs this name to buld it own index.
renaming index to another file name solved the issue
