Recommended hardware
Hey. Currently I have server with E3-1225v2, 16gb ddr3 and ssd (data backend will be OVH object storage)
Would that be enough for production ready seafile server?
Will the seafile with openstack swift backend first save the data to the server and then send it to the OVH object storage (and delete it from server or cache it?)
HW should be OK. Have 2x Intel(R) Xeon(R) CPU X5355 2.66GHz, 16GB DDR3, 250GB SSD for system and data on HDD RAID.
Don’t have experience with that.
Afaik people reported issues with Seafile OVH object storage. I’m not sure if those have been fixed. The issue was / is that OVH uses a newer Swift version than Seafile supports.
Such a server has enough power for quite some people.
They’ll fix that in next release. I’m currently waiting for that
