Recover seafile data without ccnet.conf
Due to some stupid mistakes the ccnet.conf file is permanently deleted. Is there any way I can recover the data in the seafile manually?
Thanks!
Just install another Seafile instance and copy the ccnet.conf, mykey.peer to the instance you want to recover.
If you can use docker it would probably be the easiest to run Seafile docker, and copy the files with docker cp.
