Rsync backup command
If I run incremental backup of seafile using rsync, in the manual stated using “rsync -az”.
How about deletion, do I have to specifically add -d …
thanks
I use the --delete with rsync when i backup the seafile-data to keep it equal.
Once I used the backup to restore the server it worked perfectly
