have someone a nginx configuration for seafile, where seafile is running directly in root and I can call any other website on a subfolder or a own subdomain?
Its really anoying to get some other website running on the same server.
Everytime I have to add the new folder by hand to the config file.
This is my nginx config for Seafile, maybe it will help you. I have Seafile running on a subdomain and have several other sites hosted with the same nginx instance:
/etc/nginx/sites-available/seafile
# Seafile configuration
server_name mysubdomain.mydomain.com;
proxy_pass http://localhost:8000;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
proxy_request_buffering off;
root /your/seafile/installation/path/seafile-server-latest/seahub;
access_log /var/log/nginx/media.access.log seafileformat;
error_log /var/log/nginx/media.error.log;
thank you! I will try your config.
Best
