Running Seafile behind openlitespeed
I’ve been running Seafile for several years behind nginx, without docker smoothly.
As it is time to migrate to a new server, I am wondering if anyone has tried running Seafile behind openlitespeed (ols)? This seems to be the new kid on the block, with promising speed and new features such as http/3 and strong security without additional configuration.
If I understood correctly, ols uses the same config files as Apache? So i can use those in the manual for Apache for ols as well? The tutorial includes a lot of optimizations for the nginx conf file, but none for Apache. Are there some tweaks that should be considered for ols?
Kind regards,
Ruediger
