Hello!
I have installed Seafile on an Ubuntu 16.04 instance on Lightsail by AWS Amazon and everything seems to work as it should except for the reverse proxy where I am trying to make Seafile accessible at cloud (.) mydomain (.) com rather than mydomain (.) com.
Goal:
Instead of accessing Seafile at:
mydomain.com
I want to access it at:
cloud.mydomain.com
Here are my config files:
/etc/nginx/sites-available/seafile.conf:
listen 80;
server_name cloud.MYDOMAINNAME.com;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
# If you are using [FastCGI](http://en.wikipedia.org/wiki/FastCGI),
# which is not recommended, you should use the following config for location `/`.
# location / {
# fastcgi_pass 127.0.0.1:8000;
# fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
# fastcgi_param PATH_INFO $fastcgi_script_name;
# fastcgi_param SERVER_PROTOCOL $server_protocol;
# fastcgi_param QUERY_STRING $query_string;
# fastcgi_param REQUEST_METHOD $request_method;
# fastcgi_param CONTENT_TYPE $content_type;
# fastcgi_param CONTENT_LENGTH $content_length;
# fastcgi_param SERVER_ADDR $server_addr;
# fastcgi_param SERVER_PORT $server_port;
# fastcgi_param SERVER_NAME $server_name;
# fastcgi_param REMOTE_ADDR $remote_addr;
# fastcgi_read_timeout 36000;
# client_max_body_size 0;
# access_log /var/log/nginx/seahub.access.log;
# error_log /var/log/nginx/seahub.error.log;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /home/ubuntu/seafile/seafile-server-latest/seahub;
/home/USER/seafile/conf/ccnet.conf:
[General]
USER_NAME = MY-USER-NAME
ID = SOME-STRING
NAME = MY-NAME
SERVICE_URL = http://cloud.MYDOMAINNAME.com
[Client]
PORT = 13419
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3306
USER = seafile
PASSWD = MY-VERY-LONG-PASSWORD
DB = ccnet-db
CONNECTION_CHARSET = utf8
/home/USER/seafile/conf/seahub_settings.py:
SECRET_KEY = "SECRET-KEY"
FILE_SERVER_ROOT = 'http://cloud.MYDOMAINNAME.com'
DATABASES = {
'default': {
'NAME': 'seahub-db',
'USER': 'seafile',
'PASSWORD': 'MY-LONG-PASSWORD'
'HOST': '127.0.0.1',
'PORT': '3306'
symbolic link made for seafile.conf in available-sites in enabled-sites using
ln -s /etc/nginx/sites-available/seafile.conf /etc/nginx/sites-enabled/seafile.conf
Nginx directory:
nginx
|- /conf.d
|- fastcgi_params
|- fastcgi.conf
|- koi-utf
|- koi-win
|- mime.types
|- nginx.conf
|- proxy_params
|- scgi_params
|- /sites-available
| |- seafile.conf
|- /sites-enabled
| |- seafile.conf
|- /snippets
|- uwsgi_params
|- win-utf
status output for ufw:
ubuntu@IP-ADDRESS:~$ sudo ufw status
Status: active
To Action From
22 ALLOW Anywhere
2222/tcp ALLOW Anywhere
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
21/tcp ALLOW Anywhere
443 ALLOW Anywhere
8000 ALLOW Anywhere
8082 ALLOW Anywhere
80 ALLOW Anywhere
Nginx Full ALLOW Anywhere
22 (v6) ALLOW Anywhere (v6)
2222/tcp (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
21/tcp (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
8000 (v6) ALLOW Anywhere (v6)
8082 (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
Nginx Full (v6) ALLOW Anywhere (v6)
output of sudo systemctl status nginx:
ubuntu@IP-ADDRESS:~$ sudo systemctl status nginx
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2019-01-13 12:03:23 UTC; 36min ago
Process: 2864 ExecStop=/sbin/start-stop-daemon --quiet --stop --retry QUIT/5 --pidfile /run/nginx.pid (code=exited, status=0/SUCCESS)
Process: 2876 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 2870 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 2879 (nginx)
Tasks: 2
Memory: 1.9M
CPU: 29ms
CGroup: /system.slice/nginx.service
├─2879 nginx: master process /usr/sbin/nginx -g daemon on; master_process on
└─2880 nginx: worker process
Jan 13 12:03:23 ip-172-26-8-155 systemd[1]: Starting A high performance web server and a reverse proxy server...
Jan 13 12:03:23 ip-172-26-8-155 systemd[1]: nginx.service: Failed to read PID from file /run/nginx.pid: Invalid argument
Jan 13 12:03:23 ip-172-26-8-155 systemd[1]: Started A high performance web server and a reverse proxy server.
Any and all help is appreciated.
