Save of seafile (using docker)
I would like to backup the data of my seafile that I installed using docker.
I’m currently backing up the “seafile-data” folder (db, logs, seafile, ssl). Is it enough to restore in case of a big failure?
Or do I have to save another directory?
Thanks!
When the database and the data is in this folder, it’s enough all config is in the db.
Ok thanks!
