You could place the seafile installation dir on the 50GB HDD (that’s what i would recommend) or just the seafile-data to another place:
To do so: Modify file seafile.ini under ccnet. This file contains the location of seafile-data. Move seafile-data to another place, like /opt/new/seafile-data. Then modify the file accordingly.
OR -
Create a symbolic link to the new folder like: ln -s /mnt/data/seafile/seafile-data/ /home/seafile/seafile-data
Thanks for the reply, followed your instructions and I think I got it, not sure LoL i cannot find where to check available HD space under seafile. I will start uploading files and will find out soon.
Thanks for your help!
I’m completely new to seafile.
I wanted to install seafile on a VPS using proxmox,
Was going to dedicate a 120gb ssd drive to the seafile server, and I have 14tb Seagate Exos HDD I wanted to add as the actual storage for all the files.
Would you recommend the same thing or any differences in the new versions of seafile?
There should be no difference, but i would maybe recommend to place all (seafile installation dir and data dir) on the HDD, everything else like the database and OS should be on the SSD.
