Seadrive 0.5 Sync Errors
Just to let you know… After downloading the new Seadrive 0.5 client, i have these logs : It seems that some files are not synchronized (cached) due to path letter limitations on windows
[01/19/17 12:11:19] sync-mgr.c(1810): Path ATELIERS EPCS-TITULAIRE/Suivi fiche demande de modification/170106_FM06: Production Froid CROUS is invalid on Windows, skip creating.
[01/19/17 12:11:19] sync-mgr.c(1810): Path ATELIERS EPCS-TITULAIRE/Suivi fiche demande de modification/170106_FM07: Escalier EPCS is invalid on Windows, skip creating.
[01/19/17 12:11:19] sync-mgr.c(1810): Path ATELIERS EPCS-TITULAIRE/Suivi fiche demande de modification/170113_FM08 : Equipements supplémentaires RIA INED is invalid on Windows, skip creating.
[01/19/17 12:11:19] sync-mgr.c(1810): Path ATELIERS EPCS-TITULAIRE/Suivi fiche demande de modification/170118_FM10 : Salle du Conseil INED is invalid on Windows, skip creating.
Any idea ? i can investigate further, but i need to be sure that it won’t damage files on the server…
This is a normal behavior. The mentioned files are still on the server, but just not shown in the client.
Does this mean that we can’t access these files from the client ?
I there any technical reason ?
That’s because Windows doesn’t allow such paths.
