SeaDrive 0.8.6 is ready! Fix compatibility with Visio and other software
The changelog:
  • [fix] Fix compatibility with Visio and other applications by implementing a missing system API
Hello Daniel,
can’t update from previvous version :
[1A80:2D1C][2018-03-19T07:51:14]i001: Burn v3.10.3.3007, Windows v10.0 (Build 16299: Service Pack 0), path: C:\Users\pierre\AppData\Local\Temp\{026AE270-D4DC-4730-8CEB-DE4DAFFCFDB0}\.cr\seadrive-0.8.6.exe
[1A80:2D1C][2018-03-19T07:51:14]i000: Initializing string variable 'DokanInstallFolder' to value '[ProgramFiles6432Folder]Dokan\Dokan Library-1.1.0'
[1A80:2D1C][2018-03-19T07:51:14]i009: Command Line: '-burn.clean.room=\\DISKSTATION\pierre\Downloads\seadrive-0.8.6.exe -burn.filehandle.attached=588 -burn.filehandle.self=596'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'WixBundleOriginalSource' to value '\\DISKSTATION\pierre\Downloads\seadrive-0.8.6.exe'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value '\\DISKSTATION\pierre\Downloads\'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\pierre\AppData\Local\Temp\SeaDrive_0.8.6_20180319075114.log'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'WixBundleName' to value 'SeaDrive 0.8.6'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'WixBundleManufacturer' to value 'Seafile ltd.'
[1A80:2864][2018-03-19T07:51:14]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[1A80:2864][2018-03-19T07:51:14]i000: Setting version variable 'WixBundleFileVersion' to value '0.8.6.0'
[1A80:2D1C][2018-03-19T07:51:14]i100: Detect begin, 6 packages
[1A80:2D1C][2018-03-19T07:51:14]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{65A3A986-3DC3-0101-0000-171128090627}'
[1A80:2D1C][2018-03-19T07:51:14]i052: Condition 'NOT DokanUninstallString' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'DokanUninstallString' to value 'MsiExec.exe /X{65A3A964-3DC3-0101-0000-171128090627}'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting version variable 'ADVAPIVERSION' to value '10.0.16299.192'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'vcredist_2017_x64_installed' to value '1'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting numeric variable 'vcredist_2017_x64_version' to value 1
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'vcredist_2017_x64_versionnumber' to value '14.11.25325'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'vcredist_2017_x86_installed' to value '1'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting numeric variable 'vcredist_2017_x86_version' to value 1
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting string variable 'vcredist_2017_x86_versionnumber' to value '14.11.25325'
[1A80:2D1C][2018-03-19T07:51:14]i000: Setting version variable 'WINTRUSTVERSION' to value '10.0.16299.309'
[1A80:2D1C][2018-03-19T07:51:14]i102: Detected related bundle: {967638f0-db07-4400-a396-254db8906397}, type: Upgrade, scope: PerMachine, version: 0.8.5.0, operation: MajorUpgrade
[1A80:2D1C][2018-03-19T07:51:14]i052: Condition 'DokanUninstallString OR nodriver' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:14]i052: Condition 'vcredist_2017_x86_installed AND vcredist_2017_x86_version AND vcredist_2017_x86_versionnumber >= v14.11.25325' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:14]i052: Condition 'vcredist_2017_x64_installed AND vcredist_2017_x64_version AND vcredist_2017_x64_versionnumber >= v14.11.25325' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:14]i101: Detected package: dokan_clean.exe, state: Present, cached: None
[1A80:2D1C][2018-03-19T07:51:14]i101: Detected package: vcredist_2017_x86.exe, state: Present, cached: None
[1A80:2D1C][2018-03-19T07:51:14]i101: Detected package: vcredist_2017_x64.exe, state: Present, cached: Complete
[1A80:2D1C][2018-03-19T07:51:14]i101: Detected package: Dokan_x86.msi, state: Absent, cached: None
[1A80:2D1C][2018-03-19T07:51:14]i101: Detected package: Dokan_x64.msi, state: Present, cached: Complete
[1A80:2D1C][2018-03-19T07:51:14]i101: Detected package: SeaDrivePrograms, state: Absent, cached: None
[1A80:2D1C][2018-03-19T07:51:14]i052: Condition 'Installed OR VersionNT > v6.1 OR (VersionNT = v6.1 AND ServicePackLevel >= 1)' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:14]i052: Condition 'Installed OR VersionNT > v6.1 OR (VersionNT = v6.1 AND ((WINTRUSTVERSION >= v6.1.7601.18741 AND WINTRUSTVERSION < v6.1.7601.22000) OR WINTRUSTVERSION >= v6.1.7601.22948))' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:14]i199: Detect complete, result: 0x0
[1A80:2D1C][2018-03-19T07:51:16]i200: Plan begin, 6 packages, action: Install
[1A80:2D1C][2018-03-19T07:51:16]w321: Skipping dependency registration on package with no dependency providers: dokan_clean.exe
[1A80:2D1C][2018-03-19T07:51:16]w321: Skipping dependency registration on package with no dependency providers: vcredist_2017_x86.exe
[1A80:2D1C][2018-03-19T07:51:16]i052: Condition 'VersionNT64' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:16]w321: Skipping dependency registration on package with no dependency providers: vcredist_2017_x64.exe
[1A80:2D1C][2018-03-19T07:51:16]i052: Condition 'NOT VersionNT64 AND NOT nodriver' evaluates to false.
[1A80:2D1C][2018-03-19T07:51:16]i052: Condition 'VersionNT64 AND NOT nodriver' evaluates to true.
[1A80:2D1C][2018-03-19T07:51:16]i000: Setting string variable 'WixBundleRollbackLog_SeaDrivePrograms' to value 'C:\Users\pierre\AppData\Local\Temp\SeaDrive_0.8.6_20180319075114_000_SeaDrivePrograms_rollback.log'
[1A80:2D1C][2018-03-19T07:51:16]i000: Setting string variable 'WixBundleLog_SeaDrivePrograms' to value 'C:\Users\pierre\AppData\Local\Temp\SeaDrive_0.8.6_20180319075114_000_SeaDrivePrograms.log'
[1A80:2D1C][2018-03-19T07:51:16]i201: Planned package: dokan_clean.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1A80:2D1C][2018-03-19T07:51:16]i201: Planned package: vcredist_2017_x86.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1A80:2D1C][2018-03-19T07:51:16]i201: Planned package: vcredist_2017_x64.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1A80:2D1C][2018-03-19T07:51:16]i201: Planned package: Dokan_x86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1A80:2D1C][2018-03-19T07:51:16]i201: Planned package: Dokan_x64.msi, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[1A80:2D1C][2018-03-19T07:51:16]i201: Planned package: SeaDrivePrograms, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[1A80:2D1C][2018-03-19T07:51:16]i207: Planned related bundle: {967638f0-db07-4400-a396-254db8906397}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[1A80:2D1C][2018-03-19T07:51:16]i299: Plan complete, result: 0x0
[1A80:2D1C][2018-03-19T07:51:16]i300: Apply begin
[1A80:2D1C][2018-03-19T07:51:16]i010: Launching elevated engine process.
[1A80:2D1C][2018-03-19T07:51:16]i011: Launched elevated engine process.
[1A80:2D1C][2018-03-19T07:51:16]i012: Connected to elevated engine.
[2260:2844][2018-03-19T07:51:16]i358: Pausing automatic updates.
[2260:2844][2018-03-19T07:51:16]i359: Paused automatic updates.
[2260:2844][2018-03-19T07:51:16]i360: Creating a system restore point.
[2260:2844][2018-03-19T07:51:16]w363: Could not create system restore point, error: 0x80070422. Continuing...
[2260:2844][2018-03-19T07:51:16]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee2b8260-d2e8-4216-81ed-54a2921c597c}, options: 0x7, disable resume: No
[2260:2844][2018-03-19T07:51:16]i000: Caching bundle from: 'C:\Users\pierre\AppData\Local\Temp\{929583E7-B1E1-40EF-BD59-66E70DE5235C}\.be\seadrive.exe' to: 'C:\ProgramData\Package Cache\{ee2b8260-d2e8-4216-81ed-54a2921c597c}\seadrive.exe'
[2260:2844][2018-03-19T07:51:16]i320: Registering bundle dependency provider: {ee2b8260-d2e8-4216-81ed-54a2921c597c}, version: 0.8.6.0
[2260:2844][2018-03-19T07:51:16]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee2b8260-d2e8-4216-81ed-54a2921c597c}, resume: Active, restart initiated: No, disable resume: No
[2260:2AF4][2018-03-19T07:51:18]i305: Verified acquired payload: SeaDrivePrograms at path: C:\ProgramData\Package Cache\.unverified\SeaDrivePrograms, moving to: C:\ProgramData\Package Cache\{B9D2A3A0-6F04-46AD-9479-E88FF5115458}v0.8.6\seadrive.msi.
[2260:2844][2018-03-19T07:51:18]i323: Registering package dependency provider: {65A3A964-3DC3-0101-0000-171128090627}, version: 1.1.0.1000, package: Dokan_x64.msi
[2260:2844][2018-03-19T07:51:18]i325: Registering dependency: {ee2b8260-d2e8-4216-81ed-54a2921c597c} on package provider: {65A3A964-3DC3-0101-0000-171128090627}, package: Dokan_x64.msi
[2260:2844][2018-03-19T07:51:18]i323: Registering package dependency provider: {B9D2A3A0-6F04-46AD-9479-E88FF5115458}, version: 0.8.6, package: SeaDrivePrograms
[2260:2844][2018-03-19T07:51:18]i301: Applying execute package: SeaDrivePrograms, action: Install, path: C:\ProgramData\Package Cache\{B9D2A3A0-6F04-46AD-9479-E88FF5115458}v0.8.6\seadrive.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[2260:2844][2018-03-19T07:51:33]e000: Error 0x80070643: Failed to install MSI package.
[2260:2844][2018-03-19T07:51:33]e000: Error 0x80070643: Failed to execute MSI package.
[1A80:2D1C][2018-03-19T07:51:33]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1A80:2D1C][2018-03-19T07:51:33]w348: Application requested retry of package: SeaDrivePrograms, encountered error: 0x80070643. Retrying...
[2260:2844][2018-03-19T07:51:36]i301: Applying execute package: SeaDrivePrograms, action: Install, path: C:\ProgramData\Package Cache\{B9D2A3A0-6F04-46AD-9479-E88FF5115458}v0.8.6\seadrive.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[2260:2844][2018-03-19T07:52:40]e000: Error 0x80070643: Failed to install MSI package.
[2260:2844][2018-03-19T07:52:40]e000: Error 0x80070643: Failed to execute MSI package.
[1A80:2D1C][2018-03-19T07:52:40]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1A80:2D1C][2018-03-19T07:52:40]w348: Application requested retry of package: SeaDrivePrograms, encountered error: 0x80070643. Retrying...
[2260:2844][2018-03-19T07:52:43]i301: Applying execute package: SeaDrivePrograms, action: Install, path: C:\ProgramData\Package Cache\{B9D2A3A0-6F04-46AD-9479-E88FF5115458}v0.8.6\seadrive.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[2260:2844][2018-03-19T07:53:07]e000: Error 0x80070643: Failed to install MSI package.
[2260:2844][2018-03-19T07:53:07]e000: Error 0x80070643: Failed to execute MSI package.
[1A80:2D1C][2018-03-19T07:53:07]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1A80:2D1C][2018-03-19T07:53:07]w348: Application requested retry of package: SeaDrivePrograms, encountered error: 0x80070643. Retrying...
[2260:2844][2018-03-19T07:53:10]i301: Applying execute package: SeaDrivePrograms, action: Install, path: C:\ProgramData\Package Cache\{B9D2A3A0-6F04-46AD-9479-E88FF5115458}v0.8.6\seadrive.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[2260:2844][2018-03-19T07:53:13]e000: Error 0x80070643: Failed to install MSI package.
[2260:2844][2018-03-19T07:53:13]e000: Error 0x80070643: Failed to execute MSI package.
[1A80:2D1C][2018-03-19T07:53:13]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1A80:2D1C][2018-03-19T07:53:13]i319: Applied execute package: SeaDrivePrograms, result: 0x80070643, restart: None
[1A80:2D1C][2018-03-19T07:53:13]e000: Error 0x80070643: Failed to execute MSI package.
[2260:2844][2018-03-19T07:53:13]i318: Skipped rollback of package: SeaDrivePrograms, action: Uninstall, already: Absent
[1A80:2D1C][2018-03-19T07:53:13]i319: Applied rollback package: SeaDrivePrograms, result: 0x0, restart: None
[2260:2844][2018-03-19T07:53:13]i329: Removed package dependency provider: {B9D2A3A0-6F04-46AD-9479-E88FF5115458}, package: SeaDrivePrograms
[2260:2844][2018-03-19T07:53:13]i351: Removing cached package: SeaDrivePrograms, from path: C:\ProgramData\Package Cache\{B9D2A3A0-6F04-46AD-9479-E88FF5115458}v0.8.6\
[2260:2844][2018-03-19T07:53:13]i326: Removed dependency: {ee2b8260-d2e8-4216-81ed-54a2921c597c} on package provider: {65A3A964-3DC3-0101-0000-171128090627}, package Dokan_x64.msi
[2260:2844][2018-03-19T07:53:13]i329: Removed package dependency provider: {65A3A964-3DC3-0101-0000-171128090627}, package: Dokan_x64.msi
[2260:2844][2018-03-19T07:53:13]i329: Removed package dependency provider: {65A3A986-3DC3-0101-0000-171128090627}, package: Dokan_x86.msi
[2260:2844][2018-03-19T07:53:13]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee2b8260-d2e8-4216-81ed-54a2921c597c}, resume: None, restart: None, disable resume: No
[2260:2844][2018-03-19T07:53:13]i330: Removed bundle dependency provider: {ee2b8260-d2e8-4216-81ed-54a2921c597c}
[2260:2844][2018-03-19T07:53:13]i352: Removing cached bundle: {ee2b8260-d2e8-4216-81ed-54a2921c597c}, from path: C:\ProgramData\Package Cache\{ee2b8260-d2e8-4216-81ed-54a2921c597c}\
[2260:2844][2018-03-19T07:53:13]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee2b8260-d2e8-4216-81ed-54a2921c597c}, resume: None, restart initiated: No, disable resume: No
[1A80:2D1C][2018-03-19T07:53:13]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart:  No
Uninstall manually previous version then install 0.8.6 worked fine.
May a cause of the API implementation?
