Server: 8.0.3 on Debian 10.8 x86-64
Client: Seadrive 2.0.12 on Windows 10 Pro 1909 on Surface Pro 7
Symptom: “internal error: failed to connect to SeaDrive daemon” and multiple entries in the File Explorer navigation pane.
Will post logs shortly.
Can’t figure out how to upload logs… Here’s the interesting part, from seadrive-gui.log:
[02/26/21 17:31:12] loaded 0 accounts
[02/26/21 17:31:12] starting applet rpc service
[02/26/21 17:31:12] applet rpc service started
[02/26/21 17:31:12] seadrive gui started
[02/26/21 17:31:12] cache directory not set, asking the user for it
[02/26/21 17:31:21] Using cache directory: C:/Users/marti/seadrive_root
[02/26/21 17:31:21] starting seadrive daemon: seadrive.exe "-d" "U:/seadrive/data" "-l" "C:/Users/marti/seadrive/logs/seadrive.log" "C:\\Users\\marti\\seadrive_root"
[02/26/21 17:31:24] Unable to get config value download_limit: Config not exists
[02/26/21 17:31:24] Unable to get config value upload_limit: Config not exists
[02/26/21 17:32:15] [ext listener] listening on \\.\pipe\seadrive_ext_pipe_bWFydGk=
[02/26/21 17:32:15] generated sync root name is : mrtnggnn
[02/26/21 17:32:15] Unable to switch to account https://mrtn-seafile.duckdns.org mrtnggnn@pm.me bf2f3e3 : '[' or '{' expected near end of file
[02/26/21 17:32:15] Seadrive daemon process exited normally with code -529697949
[02/26/21 17:32:20] Trying to restart seadrive daemon
[02/26/21 17:32:20] starting seadrive daemon: seadrive.exe "-d" "U:/seadrive/data" "-l" "C:/Users/marti/seadrive/logs/seadrive.log" "C:\\Users\\marti\\seadrive_root"
[02/26/21 17:32:23] Unable to switch to account https://mrtn-seafile.duckdns.org mrtnggnn@pm.me bf2f3e3 : '[' or '{' expected near end of file
[02/26/21 17:32:23] Failed to connect to named pipe: The system cannot find the file specified.
[02/26/21 17:32:24] Failed to connect to named pipe: The system cannot find the file specified.
[02/26/21 17:32:25] Failed to connect to named pipe: The system cannot find the file specified.
[02/26/21 17:32:26] Failed to connect to named pipe: The system cannot find the file specified.
[02/26/21 17:32:26] Exiting with error: internal error: failed to connect to SeaDrive daemon
[02/26/21 17:32:26] Seadrive daemon process exited normally with code -529697949
[02/26/21 17:32:31] Trying to restart seadrive daemon
[02/26/21 17:32:31] starting seadrive daemon: seadrive.exe "-d" "U:/seadrive/data" "-l" "C:/Users/marti/seadrive/logs/seadrive.log" "C:\\Users\\marti\\seadrive_root"
[02/26/21 17:32:34] Unable to switch to account https://mrtn-seafile.duckdns.org mrtnggnn@pm.me bf2f3e3 : '[' or '{' expected near end of file
[02/26/21 17:32:34] Failed to connect to named pipe: The system cannot find the file specified.
[02/26/21 17:32:35] Failed to connect to named pipe: The system cannot find the file specified.
Quite a few dumps as well.
I installed SeaDrive on my work laptop without a problem, operating on the same server/account.
Any help will be appreciated!
Done, thanks!
Do you have multiple seafile accounts with the same name? Sometimes this can cause the problem.
Only one server with one single account. Problem arose the very first time I installed Seadrive on this computer.
Thanks
I encounter just same problem after reinstalling my SeaDrive client 2.0.12: When I start SeaDrive, an error message informs me “internal error: failed to connect to SeaDrive daemon”.
The installation of SeaDrive went smoothly - no oddities observed.
When starting SeaDrive with admin permissions though, I get no error message and can use SeaDrive. @mrtn Can you observe the same behavior?
For more detailed analysis, I uploaded my dump file using the upload link in @Jonathan’s post. Here the seadrive-gui.log:
[03/07/21 01:41:20] loaded 1 accounts
[03/07/21 01:41:20] starting applet rpc service
[03/07/21 01:41:20] applet rpc service started
[03/07/21 01:41:20] seadrive gui started
[03/07/21 01:41:20] Using cache directory: C:/Users/RDB/seadrive_root
[03/07/21 01:41:20] starting seadrive daemon: seadrive.exe “-d” “C:/Users/RDB/seadrive/data” “-l” “C:/Users/RDB/seadrive/logs/seadrive.log” “-L” “de_de” “C:\Users\RDB\seadrive_root”
[03/07/21 01:41:23] Unable to get config value download_limit: Config not exists
[03/07/21 01:41:23] Unable to get config value upload_limit: Config not exists
[03/07/21 01:41:23] use exist syncroot name Ralf Dyl_1
[03/07/21 01:41:23] generated sync root name is : Ralf Dyl_1
[03/07/21 01:41:23] Unable to switch to account https://cloud.datamate.org rdb@datamate.org effdac7 : ‘[’ or ‘{’ expected near end of file
[03/07/21 01:41:23] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:24] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:25] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:26] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:26] Exiting with error: Interner Fehler: Keine Verbindung zum SeaDrive Daemon
[03/07/21 01:41:27] Seadrive daemon process exited normally with code -529697949
[03/07/21 01:41:27] use exist syncroot name Ralf Dyl_1
[03/07/21 01:41:27] generated sync root name is : Ralf Dyl_1
[03/07/21 01:41:27] failed to write to named pipe: The pipe is being closed.
[03/07/21 01:41:27] failed to send rpc call: No error
[03/07/21 01:41:27] Unable to switch to account https://cloud.datamate.org rdb@datamate.org effdac7 : Transport Error
[03/07/21 01:41:32] Trying to restart seadrive daemon
[03/07/21 01:41:32] starting seadrive daemon: seadrive.exe “-d” “C:/Users/RDB/seadrive/data” “-l” “C:/Users/RDB/seadrive/logs/seadrive.log” “-L” “de_de” “C:\Users\RDB\seadrive_root”
[03/07/21 01:41:35] Unable to switch to account https://cloud.datamate.org rdb@datamate.org effdac7 : ‘[’ or ‘{’ expected near ‘S’
[03/07/21 01:41:35] Seadrive daemon process exited normally with code -529697949
[03/07/21 01:41:36] Interner Fehler: Keine Verbindung zum SeaDrive Daemon
[03/07/21 01:41:36] failed to write to named pipe: The pipe is being closed.
[03/07/21 01:41:36] failed to send rpc call: No error
[03/07/21 01:41:36] Unable to get config value client_id: Transport Error
[03/07/21 01:41:36] Unable to set config value client_id
[03/07/21 01:41:36] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:37] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:38] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:39] Failed to connect to named pipe: The system cannot find the file specified.
[03/07/21 01:41:39] Exiting with error: Interner Fehler: Keine Verbindung zum SeaDrive Daemon
[03/07/21 01:41:39] [ext listener] listening on \.\pipe\seadrive_ext_pipe_UkRC
[03/07/21 01:41:39] app event loop exited with 1
[03/07/21 01:41:39] Unmounting before exit
[03/07/21 01:41:39] failed to write to named pipe: The pipe is being closed.
[03/07/21 01:41:39] failed to send rpc call: Invalid argument
[03/07/21 01:41:39] [Daemon Mgr] stopping seadrive daemon
[03/07/21 01:41:39] failed to stop seadrive daemon process: Transport Error
[03/07/21 01:41:39] failed to exit seadrive daemon
What does this mean:
I am asking because I have seen this error message in other log files beforehand.
@mrtn thanks for feedback. Can you check the below registry entry: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SyncRootManager ? Do you see multiple entries start with “seadrive”?
@rdb Installed for the third time and this one was OK. No problem using SeaDrive at all. No need for admin privileges. Weird.
@Jonathan yes there are 2: one with local URL and one with external URL. Will get rid of one. Thanks!
