Hey everyone!
Long time Seafile admin, first time poster
In the past I’ve never used the Seadrive but the Seafile Client. Due to a new customer who had lots of data to migrate I needed to implement Seadrive to make sure that every employee had access to all the data.
I’ve recently run in the a curious issue:
The customer told me that they were having issues while moving data.
Long story, short:
1.) I always get this error in the seahub-logfiles on the server when I do a move-operation:
[WARNING] django.request:222 log_response Bad Request: /api/v2.1/copy-move-task/
[WARNING] django.request:222 log_response Not Found: /api/v2.1/copy-move-task/
2.) if the source- and the destination path has a “&” in it I’ll get the following issue in seahub.log:
[ERROR] django.request:222 log_response Internal Server Error: /api2/repos/accc1378-d3f8-4eab-b484-5c85657b43b6/file/ Traceback (most recent call last): File "/srv/seafile-server-8.0.8/seahub/thirdpart/django/core/handlers/exception.py", line 34, in inner response = get_response(request) File "/srv/seafile-server-8.0.8/seahub/thirdpart/django/core/handlers/base.py", line 115, in _get_response response = self.process_exception_by_middleware(e, request) File "/srv/seafile-server-8.0.8/seahub/thirdpart/django/core/handlers/base.py", line 113, in _get_response response = wrapped_callback(request, *callback_args, **callback_kwargs) File "/srv/seafile-server-8.0.8/seahub/thirdpart/django/views/decorators/csrf.py", line 54, in wrapped_view return view_func(*args, **kwargs) File "/srv/seafile-server-8.0.8/seahub/thirdpart/django/views/generic/base.py", line 71, in view return self.dispatch(request, *args, **kwargs) File "/srv/seafile-server-8.0.8/seahub/seahub/api2/base.py", line 23, in dispatch response = super(APIView, self).dispatch(*a, **kw) File "/srv/seafile-server-8.0.8/seahub/thirdpart/rest_framework/views.py", line 505, in dispatch response = self.handle_exception(exc) File "/srv/seafile-server-8.0.8/seahub/seahub/api2/base.py", line 20, in handle_exception return super(APIView, self).handle_exception(exc) File "/srv/seafile-server-8.0.8/seahub/thirdpart/rest_framework/views.py", line 465, in handle_exception self.raise_uncaught_exception(exc) File "/srv/seafile-server-8.0.8/seahub/thirdpart/rest_framework/views.py", line 476, in raise_uncaught_exception raise exc File "/srv/seafile-server-8.0.8/seahub/thirdpart/rest_framework/views.py", line 502, in dispatch response = handler(request, *args, **kwargs) File "/srv/seafile-server-8.0.8/seahub/seahub/api2/views.py", line 2942, in post new_filename = check_filename_with_rename(dst_repo_id, dst_dir, filename) File "/srv/seafile-server-8.0.8/seahub/seahub/utils/__init__.py", line 339, in check_filename_with_rename exist_obj_names = [dirent.obj_name for dirent in dirents] TypeError: 'NoneType' object is not iterable
seafile.log says the following:
…/common/rpc-service.c(969): Can’t find seaf dir for /999 TES/ in repo 341f3b73-0388-4026-971d-5d4dfb57d06b
The folder in my testing setup was named “999 TES&TFOLDER”. The folder where the problem originated was name after a company, think like “AT&T”
The issue only occured when I tried to MOVE a folder which had a “&” in it. Moving single or multiple files did work as excepected.
SeaDrive Version: 2.20
Seafile-Server Version: 8.0.8
