When a reserach function will be enable on Seadrive for Mac OS ?
thank you,
Céline PORHEL
thank you,
Céline PORHEL
I’m afraid there will not be a search function for Mac OS. It is a system limitation.
Thank you very much for your fast answer. Thanks to your forum, I read an answer on an older topic that indicate this application “Easy Find”
I tried and it seems to work, do you recommand to use it ?
I don’t use it personally. Can you give it a test and post your result in the forum?
Yes, we use it and this does work. So I guess this application is OK.
