Hey guy’s!
I facing an issue since a couple of day’s. After update from Seadrive 1.0.7 to 1.0.8 it won’t work anymore. After a couple of seconds I get a dialog with the error that SeaDrive couldn’t be initialized.
Here from the log’s:
seadrive-gui.log:
[12/02/19 13:55:03] loaded 0 accounts
[12/02/19 13:55:03] starting applet rpc service
[12/02/19 13:55:03] applet rpc service started
[12/02/19 13:55:04] seadrive gui started
[12/02/19 13:55:04] Using disk letter S:
[12/02/19 13:55:04] starting seadrive daemon: seadrive.exe "-d" "C:/Users/MagesJoh/seadrive/data" "-l" "C:/Users/MagesJoh/seadrive/logs/seadrive.log" "-L" "de_de" "S:"
[12/02/19 13:55:06] Failed to connect to named pipe:
[12/02/19 13:55:08] Failed to connect to named pipe:
[12/02/19 13:55:10] Failed to connect to named pipe:
[12/02/19 13:55:12] Failed to connect to named pipe:
[12/02/19 13:55:14] Failed to connect to named pipe:
[12/02/19 13:55:16] Failed to connect to named pipe:
[12/02/19 13:55:18] Failed to connect to named pipe:
[12/02/19 13:55:20] Failed to connect to named pipe:
[12/02/19 13:55:22] Failed to connect to named pipe:
[12/02/19 13:55:24] Failed to connect to named pipe:
[12/02/19 13:55:26] Failed to connect to named pipe:
[12/02/19 13:55:28] Failed to connect to named pipe:
[12/02/19 13:55:30] Failed to connect to named pipe:
[12/02/19 13:55:32] Failed to connect to named pipe:
[12/02/19 13:55:34] Failed to connect to named pipe:
[12/02/19 13:55:36] Failed to connect to named pipe:
[12/02/19 13:55:36] seadrive rpc is not ready after 16 retry, abort
[12/02/19 13:55:36] Exiting with error: SeaDrive konnte nicht initialisiert werden (Transl.: SeaDrive couldn't be initialized.)
[12/02/19 13:55:45] SeaDrive konnte nicht initialisiert werden (Transl.: SeaDrive couldn't be initialized.)
[12/02/19 13:55:45] app event loop exited with 1
[12/02/19 13:55:45] Not unmounting because rpc client not ready.
[12/02/19 13:55:45] [Daemon Mgr] stopping seadrive daemon
[12/02/19 13:55:45] Seadrive daemon process crashed with code 62097
seadrive.log:
[12/02/19 13:55:05] seadrive.c(697): Starting SeaDrive client 1.0.8
[12/02/19 13:55:05] seadrive.c(699): SeaDrive client source code version 840de1e28786f3d791d6126dc04664eec9b9605b
[12/02/19 13:55:05] seadrive.c(725): rpc server started.
[12/02/19 13:55:05] seadrive.c(745): Mount virtual drive as removable disk.
It’s a company PC that is in a domain. But that should not be the issue because it worked properly before.
System: Windows 10 Enterprise 1803 (Build 17134.1130)
What I already did:
- Un- and reinstalled SeaDrive properly as default user with special elevated rights and as local administrator
- Changed back to 1.0.7 -> don’t work anymore too
- Un- and reinstalled the MS VC redist’s.
- Un- and reinstalled the Dokan library.
- Used the repair function
And nothing worked. Our Service Desk said that the cancel the support at this point because it’s an issue by the Seafile Co.
If you need some more information’s so please let me know.
