Seadrive keeps giving me hard time. The main problems are its verbosity level and recoverability.
Recently I have this problem. It stops syncing with the error “Operation was aborted by an application callback.” or “Failed to get file 4019dee3a00bbac4c7a867e66ed43f03dbee0d50 in repo 3747c53d.”. So what is it telling? I checked the logs on the server. No errors. I have to remove seadrives meta directory to sort this out.
[10/17/18 12:14:55] sync-mgr.c(1413): All repo fs trees are loaded.
[10/17/18 12:14:55] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'uploading'.
[10/17/18 12:14:55] http-tx-mgr.c(3919): Upload with HTTP sync protocol version 2.
[10/17/18 12:14:55] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'init') --> ('normal', 'check')
[10/17/18 12:14:55] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'check') --> ('normal', 'commit')
[10/17/18 12:14:55] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'commit') --> ('normal', 'fs')
[10/17/18 12:14:56] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'fs') --> ('normal', 'data')
[10/17/18 12:14:56] fs-mgr.c(591): [fs mgr] Failed to read file 4019dee3a00bbac4c7a867e66ed43f03dbee0d50.
[10/17/18 12:14:56] http-tx-mgr.c(3655): Failed to get file 4019dee3a00bbac4c7a867e66ed43f03dbee0d50 in repo 3747c53d.
[10/17/18 12:14:56] http-tx-mgr.c(911): libcurl failed to PUT https://hostname/seafhttp/repo/3747c53d-9548-43bc-9b6c-1c6173a56720/block/dc7bef76aa0533d1c7f9992a1398eb97daf83540: Operation was aborted by an application callback.
[10/17/18 12:14:56] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'data') --> ('error', 'finished')
[10/17/18 12:14:56] sync-mgr.c(604): Repo 'pdfs' sync state transition from uploading to 'error': 'Error occured in upload.'.
[10/17/18 12:15:26] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'uploading'.
[10/17/18 12:15:26] http-tx-mgr.c(3919): Upload with HTTP sync protocol version 2.
[10/17/18 12:15:26] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'init') --> ('normal', 'check')
[10/17/18 12:15:26] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'check') --> ('normal', 'commit')
[10/17/18 12:15:26] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'commit') --> ('normal', 'fs')
[10/17/18 12:15:27] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'fs') --> ('normal', 'data')
[10/17/18 12:15:27] fs-mgr.c(591): [fs mgr] Failed to read file 4019dee3a00bbac4c7a867e66ed43f03dbee0d50.
[10/17/18 12:15:27] http-tx-mgr.c(3655): Failed to get file 4019dee3a00bbac4c7a867e66ed43f03dbee0d50 in repo 3747c53d.
[10/17/18 12:15:27] http-tx-mgr.c(911): libcurl failed to PUT https://hostname/seafhttp/repo/3747c53d-9548-43bc-9b6c-1c6173a56720/block/dc7bef76aa0533d1c7f9992a1398eb97daf83540: Operation was aborted by an application callback.
[10/17/18 12:15:27] http-tx-mgr.c(911): libcurl failed to PUT https://hostname/seafhttp/repo/3747c53d-9548-43bc-9b6c-1c6173a56720/block/a9d6a22388e4aa963c579786ee66ad5e74cd41b8: Operation was aborted by an application callback.
[10/17/18 12:15:27] http-tx-mgr.c(1186): Transfer repo '3747c53d': ('normal', 'data') --> ('error', 'finished')
[10/17/18 12:15:27] sync-mgr.c(604): Repo 'pdfs' sync state transition from uploading to 'error': 'Error occured in upload.'.
Second problem which occurs since the time I installed seadrive
[10/11/18 11:27:41] http-tx-mgr.c(3878): Upload with HTTP sync protocol version 2.
[10/11/18 11:27:41] http-tx-mgr.c(1145): Transfer repo '3747c53d': ('normal', 'init') --> ('normal', 'check')
[10/11/18 11:27:41] http-tx-mgr.c(1145): Transfer repo '3747c53d': ('normal', 'check') --> ('normal', 'commit')
[10/11/18 11:27:41] http-tx-mgr.c(1145): Transfer repo '3747c53d': ('normal', 'commit') --> ('normal', 'fs')
[10/11/18 11:27:42] http-tx-mgr.c(1145): Transfer repo '3747c53d': ('normal', 'fs') --> ('normal', 'data')
[10/11/18 11:27:46] http-tx-mgr.c(1145): Transfer repo '3747c53d': ('normal', 'data') --> ('normal', 'update-branch')
[10/11/18 11:27:46] http-tx-mgr.c(1145): Transfer repo '3747c53d': ('normal', 'update-branch') --> ('finished', 'finished')
[10/11/18 11:27:46] sync-mgr.c(2326): removing blocks for repo 3747c53d-9548-43bc-9b6c-1c6173a56720
[10/11/18 11:27:46] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'uploading' to 'get sync info'.
[10/11/18 11:27:46] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'get sync info' to 'synchronized'.
[10/11/18 11:27:46] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'committing'.
[10/11/18 11:27:47] sync-mgr.c(2616): Creating partial commit after adding pdfs/6210.pdf in repo pdfs(3747c53d).
[10/11/18 11:27:47] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'committing' to 'synchronized'.
[10/11/18 11:27:47] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'committing'.
[10/11/18 11:27:48] sync-mgr.c(2616): Creating partial commit after adding pdfs/6387.pdf in repo pdfs(3747c53d).
[10/11/18 11:27:48] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'committing' to 'synchronized'.
[10/11/18 11:27:48] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'committing'.
[10/11/18 11:27:49] sync-mgr.c(2616): Creating partial commit after adding pdfs/6210.pdf in repo pdfs(3747c53d).
[10/11/18 11:27:49] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'committing' to 'synchronized'.
[10/11/18 11:27:49] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'committing'.
[10/11/18 11:27:50] sync-mgr.c(2616): Creating partial commit after adding pdfs/6387.pdf in repo pdfs(3747c53d).
[10/11/18 11:27:50] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'committing' to 'synchronized'.
[10/11/18 11:27:50] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'committing'.
[10/11/18 11:27:51] sync-mgr.c(2616): Creating partial commit after adding pdfs/6210.pdf in repo pdfs(3747c53d).
[10/11/18 11:27:51] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'committing' to 'synchronized'.
[10/11/18 11:27:51] sync-mgr.c(570): Repo 'pdfs' sync state transition from 'synchronized' to 'committing'.
[10/11/18 11:27:52] sync-mgr.c(2616): Creating partial commit after adding pdfs/6387.pdf in repo pdfs(3747c53d).
............. never ending "partial commit" loop continues ..............
I’m on Ubuntu 18 using cli only
