SeaDrive will not launch on Catalina
I am unable to launch SeaDrive 2.0.13 on MacOS Catalina 10.15.7
I see this error in the console:
default 10:44:34.054424-0400 seadrive-gui Trust evaluate failure: [leaf TemporalValidity]
And in seadrive-gui.log:
reaching max tries of restarting seadrive daemon, aborting
Exiting with error: SeaDrive exited unexpectedly
Any ideas on how to get around this?
Are you running macFUSE 4.1.0? I received an error until I updated.
Yes, I am running macFUSE 4.1.0. I have also tried disabling SIP, and have tried older versions of both SeaDrive and macFUSE as well. I cannot find any combinations that will launch SeaDrive. Older versions seem to have issues with FUSE, but the more recent versions of SeaDrive give this Trust evaluate failure. It seems like the trust error may be related to the certificate for the SeaDrive app, but if so, I do not know how to resolve it.
What version of the server are you running and are you using SSL?
Can you check seadrive.log and seadrive-gui.log for errors?
I have not got to the point where I was able to provide my server information. The first and only gui interaction is a pop up message that states:
“SeaDrive exited unexpectedly”
As mentioned, the only UI message I get is
This occures before having a chance to enter any server information.
These are the log messages:
MacOS Console:
default 07:29:17.820787-0400 seadrive-gui UNIX error exception: 17
default 07:29:18.135730-0400 seadrive-gui Trust evaluate failure: [leaf TemporalValidity]
seadrive-gui.log
[04/26/21 07:29:23] failed to run “diskutil umount /Volumes/Macintosh HD/Users/myusername/SeaDrive”
[04/26/21 07:29:23] starting seadrive daemon: seadrive “-d” “/Volumes/Macintosh HD/Users/myusername/.seadrive/data” “-l” “/Volumes/Macintosh HD/Users/myusername/.seadrive/logs/seadrive.log” “-f” “/Volumes/Macintosh” “HD/Users/myusername/SeaDrive” “-o” “volname=SeaDrive,auto_xattr”
[04/26/21 07:29:23] Seadrive daemon process exited normally with code 0
[04/26/21 07:29:23] reaching max tries of restarting seadrive daemon, aborting
[04/26/21 07:29:23] Exiting with error: SeaDrive exited unexpectedly
04/26/21 07:30:04] SeaDrive exited unexpectedly
seadrive.log
[04/26/21 07:29:18] seadrive.c(645): Starting SeaDrive client 2.0.13
[04/26/21 07:29:18] seadrive.c(647): SeaDrive client source code version 4d49764080ff95e5c338ea2f1f67c36f234ecd06
[04/26/21 07:29:18] socket file exists, delete it anyway
[04/26/21 07:29:18] seadrive.c(673): rpc server started.
[04/26/21 07:29:23] seadrive.c(645): Starting SeaDrive client 2.0.13
[04/26/21 07:29:23] seadrive.c(647): SeaDrive client source code version 4d49764080ff95e5c338ea2f1f67c36f234ecd06
[04/26/21 07:29:23] socket file exists, delete it anyway
[04/26/21 07:29:23] seadrive.c(673): rpc server started.
Looks like SeaDrive cannot connect to macFuse. Do you have special security settings or anti virus software on your Mac?
I do not have special security settings nor anti virus software. Based on some google search info I found, it seems I may have some dylib that is getting picked up causing the certificate error. But I cannot identify what that may be.
I revisited this problem after giving up for a long while. I have found the issue. It is not handling spaces in the path name for one of the parameters(“-f”) when starting seadrive daemon.
starting seadrive daemon: seadrive “-d” “/Volumes/Secondary Macintosh HD/myusename/.seadrive/data” “-l” “/Volumes/Secondary Macintosh HD/myusername/.seadrive/logs/seadrive.log” “-f” “/Volumes/Secondary” “Macintosh” “HD/myusername/SeaDrive” “-o” “volname=SeaDrive,auto_xattr”
When I renamed my drive to “Secondary_Macintosh_HD” to remove the spaces, then it started working.
My use case may not be common. My OS drive is small, so I have moved my user folder to a second drive with more space. That is why I have name the other drive “Secondary Macintosh HD”. Nonetheless, it seems Seadrive should handle the spaces in the path name without issues.
Thanks for the update. We’ll check the code.
