I just ran seaf-fsck on a repo that causes some errors in seafile.log. The process crashed after a while with the following errors:
[seafile@xxx seafile-server-latest]$ ./seaf-fsck.sh -r b6bb5186-4beb-4a98-b064-5b6c7fe5b088
Starting seaf-fsck, please wait ...
[09/24/19 09:26:09] fsck.c(599): Running fsck for repo b6bb5186-4beb-4a98-b064-5b6c7fe5b088.
[09/24/19 09:26:10] fsck.c(425): Checking file system integrity of repo Seafile(b6bb5186)...
[09/24/19 10:14:55] fsck.c(102): Repo[b6bb5186] block b6bb5186-4beb-4a98-b064-5b6c7fe5b088:bad0086f3ebd0c30be114f90736e1491b209f250 is missing.
[09/24/19 10:14:55] ../../common/block-backend-fs.c(85): [block bend] failed to open block bad0086f3ebd0c30be114f90736e1491b209f250 for read: No such file or directory
[09/24/19 10:14:55] ../../common/block-mgr.c(768): Failed to open block b6bb5186-4beb-4a98-b064-5b6c7fe5b088:bad0086f.
*** Error in `/home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck': free(): invalid size: 0x000000000170dd60 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x816b9)[0x7f029843d6b9]
/home/seafile/seafile-pro-server-7.0.9/seafile/lib/libglib-2.0.so.0(g_free+0xe)[0x7f029ce10bce]
/home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck[0x408723]
/home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck[0x4086f6]
/home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck[0x4093ed]
/home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck[0x409673]
/home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck[0x407a08]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7f02983de545]
/home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck[0x407b19]
======= Memory map: ========
00400000-0044b000 r-xp 00000000 fd:02 4235693 /home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck
0064a000-0064b000 r--p 0004a000 fd:02 4235693 /home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck
0064b000-0064c000 rw-p 0004b000 fd:02 4235693 /home/seafile/seafile-pro-server-7.0.9/seafile/bin/seaf-fsck
I started seaf-fsck again without the repair option, and I’m getting a segmentation fault (line 46 in seaf-fsck.sh):
[09/24/19 13:19:29] ../../common/block-backend-fs.c(85): [block bend] failed to open block bad0086f3ebd0c30be114f90736e1491b209f250 for read: No such file or directory
[09/24/19 13:19:29] ../../common/block-mgr.c(768): Failed to open block b6bb5186-4beb-4a98-b064-5b6c7fe5b088:bad0086f.
./seaf-fsck.sh: Zeile 46: 81293 Speicherzugriffsfehler LD_LIBRARY_PATH=$SEAFILE_LD_LIBRARY_PATH ${seaf_fsck} -c "${default_ccnet_conf_dir}" -d "${seafile_data_dir}" -F "${default_conf_dir}" ${seaf_fsck_opts}
BTW, I’m using Scientific Linux 7.7
No problem for me (but with few repos and files)
We’ll look into the problem.
Hi @uosseafile
Can you still reproduce the issue? We cannot reproduce it in our testing environment. So we’ll have to provide you with a debug package, then you send back the back trace to us.
Hi Jonathan,
I just ran seaf-fsck on the same library again with a similar result:
[seafile@xxx seafile-server-latest]$ ./seaf-fsck.sh b6bb5186-...-5b6c7fe5b088
[12/10/19 09:48:40] fsck.c(599): Running fsck for repo b6bb5186-...-5b6c7fe5b088.
[12/10/19 09:48:41] fsck.c(425): Checking file system integrity of repo Seafile(b6bb5186)...
[12/10/19 10:38:42] fsck.c(102): Repo[b6bb5186] block b6bb5186-4beb-4a98-b064-5b6c7fe5b088:bad0086f3ebd0c30be114f90736e1491b209f250 is missing.
[12/10/19 10:38:42] ../../common/block-backend-fs.c(85): [block bend] failed to open block bad0086f3ebd0c30be114f90736e1491b209f250 for read: No such file or directory
[12/10/19 10:38:42] ../../common/block-mgr.c(768): Failed to open block b6bb5186-4beb-4a98-b064-5b6c7fe5b088:bad0086f.
[12/10/19 10:39:10] fsck.c(102): Repo[b6bb5186] block b6bb5186-4beb-4a98-b064-5b6c7fe5b088:7eefe2e0c677897c97c305e94296c090f6e4f7bc is missing.
[12/10/19 10:39:10] ../../common/block-backend-fs.c(85): [block bend] failed to open block 7eefe2e0c677897c97c305e94296c090f6e4f7bc for read: No such file or directory
[12/10/19 10:39:10] ../../common/block-mgr.c(768): Failed to open block b6bb5186-4beb-4a98-b064-5b6c7fe5b088:7eefe2e0.
*** Error in `/home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck': corrupted size vs. prev_size: 0x0000000001956010 ***
/lib64/libc.so.6(+0x80fc7)[0x7f062e689fc7]
/lib64/libc.so.6(+0x8159e)[0x7f062e68a59e]
/home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0(g_free+0xe)[0x7f063305dbce]
/home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0(+0x38c19)[0x7f0633046c19]
/home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0(g_hash_table_remove_all+0x5b)[0x7f0633047a0b]
/home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0(g_hash_table_destroy+0xe)[0x7f0633047a4e]
/home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck[0x4093fa]
/home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck[0x409673]
/home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck[0x407a08]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7f062e62b545]
/home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck[0x407b19]
00400000-0044b000 r-xp 00000000 fd:02 7038259 /home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck
0064a000-0064b000 r--p 0004a000 fd:02 7038259 /home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck
0064b000-0064c000 rw-p 0004b000 fd:02 7038259 /home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck
0064c000-0064d000 rw-p 00000000 00:00 0
017c2000-0196e000 rw-p 00000000 00:00 0 [heap]
7f062a50b000-7f062a70a000 ---p 00025000 fd:02 522017 /home/seafile/seafile-pro-server-7.0.10/seafile/lib/liblzma.so.5./seaf-fsck.sh: line 46: 105476 Aborted LD_LIBRARY_PATH=$SEAFILE_LD_LIBRARY_PATH ${seaf_fsck} -c "${default_ccnet_conf_dir}" -d "${seafile_data_dir}" -F "${default_conf_dir}" ${seaf_fsck_opts}
It is a very big library with more than 30,000 files.
Hi @uosseafile
You can download the debug version here: https://download.seafile.com/f/57c929b0af234cb89fe0/?dl=1
Before running, please run following command first.
ulimit -c unlimited
After the problem occurs, there should be a ‘core’ file in the current directory. Please run gdb to print the stack trace of the crash.
gdb seafile-server-latest/seafile/bin/seaf-fsck core
Then enter ‘backtrace’ command in gdb prompt.
Hi @Jonathan,
thanks, that’s what I got:
Core was generated by `/home/seafile/seafile-pro-server-7.0.10/seafile/bin/seaf-fsck -c /home/seafile/'.
Program terminated with signal 6, Aborted.
#0 0x00007f6ee98c0377 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:55
55 return INLINE_SYSCALL (tgkill, 3, pid, selftid, sig);
(gdb) backtrace
#1 0x00007f6ee98c1a68 in __GI_abort () at abort.c:90
#2 0x00007f6ee9902ec7 in __libc_message (do_abort=2, fmt=fmt@entry=0x7f6ee9a153f8 "*** Error in `%s': %s: 0x%s ***\n") at ../sysdeps/unix/sysv/linux/libc_fatal.c:196
#3 0x00007f6ee990afc7 in malloc_printerr (ar_ptr=0x7f6ee9c51760 <main_arena>, ptr=0x1ba1b00, str=0x7f6ee9a12a77 "corrupted size vs. prev_size", action=<optimized out>) at malloc.c:4967
#4 malloc_consolidate (av=av@entry=0x7f6ee9c51760 <main_arena>) at malloc.c:4161
#5 0x00007f6ee990b59e in _int_free (av=0x7f6ee9c51760 <main_arena>, p=0x1c05200, have_lock=0) at malloc.c:4053
#6 0x00007f6eee2debce in g_free () from /home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0
#7 0x00007f6eee2c7c19 in g_hash_table_remove_all_nodes.part.0 () from /home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0
#8 0x00007f6eee2c8a0b in g_hash_table_remove_all () from /home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0
#9 0x00007f6eee2c8a4e in g_hash_table_destroy () from /home/seafile/seafile-pro-server-7.0.10/seafile/lib/libglib-2.0.so.0
#10 0x00000000004093fa in check_and_recover_repo (repair=0, reset=0, repo=0x1b0aec0) at fsck.c:442
#11 repair_repo (repo_id=repo_id@entry=0x1b01d50 "b6bb5186-4beb-4a98-b064-5b6c7fe5b088", repair=repair@entry=0) at fsck.c:659
#12 0x0000000000409673 in repair_repos (max_thread_num=0, repair=0, repo_id_list=0x1adda40) at fsck.c:701
#13 seaf_fsck (repo_id_list=repo_id_list@entry=0x1adda40, repair=repair@entry=0, max_thread_num=max_thread_num@entry=0) at fsck.c:716
#14 0x0000000000407a08 in main (argc=<optimized out>, argv=<optimized out>) at seaf-fsck.c:202
I hope this helps.
Dirk
Hi @uosseafile
Sorry for the late reply. We analyze the issue but could not find any real issue in the code. A possible cause is that the library’s directory hierarchy is too deep to be traversed recursively, causing the fsck program to overrun its stack. Is the library’s directory hierarchy very deep?
Hi Jonathan,
the library contains a huge number of files. Maybe the user tried to backup her drive with seafile. I will try to talk to her.
Thanks for your support.
Dirk
