I’m getting errors when accessing data from a library:
https://seafile.example.com/seafhttp/files/c2dd59fe-05b7-4fd0-8259-194d3ece519b/ABBYY_FineReader_14.exe
Which gives me:
Secure Connection Failed
An error occurred during a connection to seafile.example.com.
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
Learn more…
nginx output:
tail /var/log/nginx/error.log
2022/12/14 16:50:26 [error] 991#991: *154122 upstream prematurely closed connection while reading upstream, client: 130.130.130.130, server: seafile.example.com, request: "GET /seafhttp/files/c2dd59fe-05b7-4fd0-8259-194d3ece519b/ABBYY_FineReader_14.exe HTTP/2.0", upstream: "http://127.0.0.1:8082/files/c2dd59fe-05b7-4fd0-8259-194d3ece519b/ABBYY_FineReader_14.exe", host: "seafile.example.com", referrer: "https://seafile.example.com/library/4ad6f367-a0d4-4f75-8b7f-65df3bdac157/Software/Abby"
seafile log:
tail seafile.log
2022-12-14 16:50:26 ../common/block-backend-fs.c(70): [block bend] failed to open block a998ed057668fdfad7890ad9559ecbbe6b1ef613 for read: No such file or directory
2022-12-14 16:50:26 access-file.c(288): Failed to open block 4ad6f367-a0d4-4f75-8b7f-65df3bdac157:a998ed057668fdfad7890ad9559ecbbe6b1ef613
so the Library seems corrupted. I tried to fix it with seaf-fsck.sh:
seafile@seafile:~/seafile-server-latest$ ./seaf-fsck.sh 4ad6f367-a0d4-4f75-8b7f-65df3bdac157
Starting seaf-fsck, please wait ...
2022-12-13 18:15:59 fsck.c(596): Running fsck for repo 4ad6f367-a0d4-4f75-8b7f-65df3bdac157.
2022-12-13 18:15:59 fsck.c(422): Checking file system integrity of repo Software(4ad6f367)...
./seaf-fsck.sh: Zeile 32: 26436 Speicherzugriffsfehler LD_LIBRARY_PATH=$SEAFILE_LD_LIBRARY_PATH ${seaf_fsck} -c "${default_ccnet_conf_dir}" -d "${default_seafile_data_dir}" -F "${default_conf_dir}" ${seaf_fsck_opts}
seaf-fsck run done
Done.
Which give me a segmentation fault:
tail /var/log/messages
Dec 13 18:33:54 seafile kernel: [12739224.756826] seaf-fsck[26436]: segfault at 40 ip 000055b3986f8a22 sp 00007ffd6fa3d1a0 error 4 in seaf-fsck[55b3986f2000+26000]
Dec 13 18:33:54 seafile kernel: [12739224.757726] Code: 17 22 00 48 8b 4c 24 10 41 8b 94 24 10 01 00 00 48 8b 78 40 49 8d b4 24 14 01 00 00 48 89 74 24 48 89 54 24 54 e8 6e 7e 00 00 <44> 8b 58 40 49 89 c5 45 85 db 0f 84 d2 03 00 00 49 8d 44 24 08 4c
This is a very old Library and I will need to repair it. Deleting and rebuilding it will be a real pita.
The Server runs Debian 10 (buster) and seafile is the CE Edition 9.0.8.
Thanks for help!
