Seaf-gc.sh: Wrong ID error
I got this error when running seaf-gc.sh:
root@seafile:/home/administrator/haiwen/seafile-server-6.0.8# . seaf-gc.sh
Starting seafserv-gc, please wait …
[03/07/18 17:07:13] ccnet_client_load_confdir: Wrong ID
Trace/breakpoint trap (core dumped)
seafserv-gc run done
Done.
I’m sure I ran seaf-gc.sh before (successfully), so I don’t think the problem is because I have no user “seafile” (I installed and run seafile via “administrator”). I did stop the seafile-services before running it.
I also tried “seafserv-gc -c /home/administrator/haiwen/ccnet/ -d /home/administrator/haiwen/seafile-data/ -F /home/administrator/haiwen/conf/”, looks like this should do the same
root@seafile:/home/administrator/haiwen/seafile-server-latest# seafserv-gc -c /home/administrator/haiwen/ccnet/ -d /home/administrator/haiwen/seafile-data/ -F /home/administrator/haiwen/conf/
seafserv-gc: error while loading shared libraries: libccnet.so.0: cannot open shared object file: No such file or directory
Accorded to the Seafile-Manual you can also run “seaf-gc.sh --dry-run [repo-id1] [repo-id2] …”. But what are those repos, and how to find out what " repos" I have?
Thanks.
Isn’t “seaf-gc” some fundamental function of Seafile? How comes noone seems to know how to use it?
Reading the Source Code https://github.com/haiwen/ccnet/blob/master/lib/ccnet-client.c:
id = ccnet_util_key_file_get_string (key_file, “General”, “ID”);
if ( (id == NULL) || (strlen (id) != SESSION_ID_LENGTH)
|| (ccnet_util_hex_to_sha1 (id, sha1) < 0) )
ccnet_error (“Wrong ID\n”);
g_key_file_free (key_file);
goto onerror;
So you have a problem with the parameter ID in the section [General] in the config file /home/administrator/haiwen/conf/ccnet.conf
You need to set the LD_LIBRARY_PATH for this to work correctly:
LD_LIBRARY_PATH=/home/administrator/haiwen/seafile-server-latest/seafile/lib seafserv-gc -c […]
Because for us this tool simply works.
Solved. I used the following command to run Gargabe Collector:
export LD_LIBRARY_PATH=./lib:${LD_LIBRARY_PATH} && ./bin/seafserv-gc -c /home/administrator/haiwen/ccnet -d /home/administrator/haiwen/seafile-data -F /home/administrator/haiwen/conf
This “export […]” thing needs to set first.
