I had some issues running the upgrade script because python3 does not take “%” in passwords well. Also - at least for production - I am still migrating former templates to new react config for 7.0/7.1.
But apart from that I could work out the update in a testing environment.
axstet
May 17, 2020, 8:10pm
22
I just noticed that I get the same error on 7.1.3. After putting export PYTHONPATH=${INSTALLPATH}/seafile/lib/python3.7/site-packages:${INSTALLPATH}/seafile/lib64/python3.7/site-packages:${INSTALLPATH}/seahub:${INSTALLPATH}/seahub/thirdpart:$PYTHONPATH from seahub.sh in seafile.sh, the error is gone and seafdav starts. Wondering where the PYTHONPATH for seafdav is set since it is using libs from seahub/thirdparty but is started from seafile.sh.
I compared the two files (seafile.sh and seahub.sh) but the PYTHONPATH environment variable appears to be set to the same paths.
axstet
May 19, 2020, 3:43pm
24
Interesting, because I do not see PYTHONPATH beeing set at all in seafile.sh.
Is seafdav broken in 7.1.4? I am seeing the same logs in controller.log:
[08/05/20 18:43:25] seafile-controller.c(79): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /srv/logs/seafdav.log --pid /srv/pids/seafdav.pid --port 8080 --host 0.0.0.0
[08/05/20 18:43:25] seafile-controller.c(94): spawned /usr/bin/python3, pid 833529
[08/05/20 18:43:35] seafile-controller.c(414): pid file /srv/pids/seafdav.pid does not exist
[08/05/20 18:43:35] seafile-controller.c(446): seafdav need restart...
[08/05/20 18:43:35] seafile-controller.c(79): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /srv/logs/seafdav.log --pid /srv/pids/seafdav.pid --port 8080 --host 0.0.0.0
[08/05/20 18:43:35] seafile-controller.c(94): spawned /usr/bin/python3, pid 833619
[08/05/20 18:43:45] seafile-controller.c(414): pid file /srv/pids/seafdav.pid does not exist
[08/05/20 18:43:45] seafile-controller.c(446): seafdav need restart...
[08/05/20 18:43:45] seafile-controller.c(79): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /srv/logs/seafdav.log --pid /srv/pids/seafdav.pid --port 8080 --host 0.0.0.0
[08/05/20 18:43:45] seafile-controller.c(94): spawned /usr/bin/python3, pid 833705
[08/05/20 18:43:55] seafile-controller.c(414): pid file /srv/pids/seafdav.pid does not exist
[08/05/20 18:43:55] seafile-controller.c(446): seafdav need restart...
[08/05/20 18:43:55] seafile-controller.c(79): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /srv/logs/seafdav.log --pid /srv/pids/seafdav.pid --port 8080 --host 0.0.0.0
[08/05/20 18:43:55] seafile-controller.c(94): spawned /usr/bin/python3, pid 833774
It just keeps looping over and over like that. Those processes don’t exist in ps. I think it is crashing at start up. If I run that command myself I get:
$ sudo /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /srv/logs/seafdav.log --pid /srv/pids/seafdav.pid --port 8080 --host 0.0.0.0
usage: wsgidav [-h] [-p PORT] [-H HOST] [-r ROOT_PATH] [--auth {anonymous,nt,pam-login}] [--server {paste,gevent,cheroot,cherrypy,ext-wsgiutils,flup-fcgi,flup-fcgi_fork,wsgiref}] [--ssl-adapter {builtin,pyopenssl}] [-v | -q] [-c CONFIG_FILE | --no-config] [-V]
wsgidav: error: argument --server: invalid choice: 'gunicorn' (choose from 'paste', 'gevent', 'cheroot', 'cherrypy', 'ext-wsgiutils', 'flup-fcgi', 'flup-fcgi_fork', 'wsgiref')
I tried setting the PYTHONPATH in seafile.sh but that did not solve the issue.
WebDAV is critical for me since it is the only way to sync seafile files to Android currently. No one has a solution?
axstet
August 6, 2020, 4:55am
26
Did you check python dependencies?
Looking back over all the posts on WebDAV 502 errors I decided to check that all the software dependencies were met for the upgrade to 7.1.2.
The Manual specifically calls out
pip3 install --timeout=3600 Pillow pylibmc captcha jinja2 sqlalchemy psd-tools django-pylibmc django-simple-captcha python3-ldap
For those who come after it might be worth mentioning that pip3 might need to be installed in your system too.
sudo apt install python3-pip
You can check if it’s installed and its versio…
100
January 7, 2021, 3:55pm
27
Same issue here. Has anybody found a solution?
