Seafile pro 7.0.4
After some server maintenance (kernel update, seafile update, general yum update) seafile doesn’t start correctly after startup. If I am starting seafile by commands
systemctl stop seafile
systemctl start seafile
seafile starts normally.
Log files:
Controller.log:
[07/18/19 07:08:08] seafile-controller.c(94): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /mnt/D/Documents/seafile/conf/seafevents.conf --logfile /mnt/D/Documents/seafile/logs/seafevents.log -P /mnt/D/Documents/seafile/pids/seafevents.pid
[07/18/19 07:08:08] seafile-controller.c(109): spawned /usr/bin/python2.7, pid 3534
[07/18/19 07:08:18] seafile-controller.c(605): path /proc/3534 doesn’t exist, restart progress [3]
[07/18/19 07:08:18] seafile-controller.c(625): seafevents need restart…
[07/18/19 07:08:18] seafile-controller.c(94): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /mnt/D/Documents/seafile/conf/seafevents.conf --logfile /mnt/D/Documents/seafile/logs/seafevents.log -P /mnt/D/Documents/seafile/pids/seafevents.pid
[07/18/19 07:08:18] seafile-controller.c(109): spawned /usr/bin/python2.7, pid 3546
[07/18/19 07:08:28] seafile-controller.c(605): path /proc/3546 doesn’t exist, restart progress [3]
[07/18/19 07:08:28] seafile-controller.c(625): seafevents need restart…
[07/18/19 07:08:28] seafile-controller.c(94): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /mnt/D/Documents/seafile/conf/seafevents.conf --logfile /mnt/D/Documents/seafile/logs/seafevents.log -P /mnt/D/Documents/seafile/pids/seafevents.pid
[07/18/19 07:08:28] seafile-controller.c(109): spawned /usr/bin/python2.7, pid 3559
[07/18/19 07:08:38] seafile-controller.c(605): path /proc/3559 doesn’t exist, restart progress [3]
[07/18/19 07:08:38] seafile-controller.c(625): seafevents need restart…
[07/18/19 07:08:38] seafile-controller.c(94): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /mnt/D/Documents/seafile/conf/seafevents.conf --logfile /mnt/D/Documents/seafile/logs/seafevents.log -P /mnt/D/Documents/seafile/pids/seafevents.pid
[07/18/19 07:08:38] seafile-controller.c(109): spawned /usr/bin/python2.7, pid 3570
[07/18/19 07:08:48] seafile-controller.c(605): path /proc/3570 doesn’t exist, restart progress [3]
[07/18/19 07:08:48] seafile-controller.c(625): seafevents need restart…
[07/18/19 07:08:48] seafile-controller.c(94): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /mnt/D/Documents/seafile/conf/seafevents.conf --logfile /mnt/D/Documents/seafile/logs/seafevents.log -P /mnt/D/Documents/seafile/pids/seafevents.pid
[07/18/19 07:08:48] seafile-controller.c(109): spawned /usr/bin/python2.7, pid 3601
[07/18/19 07:08:58] seafile-controller.c(605): path /proc/3601 doesn’t exist, restart progress [3]
[07/18/19 07:08:58] seafile-controller.c(625): seafevents need restart…
[07/18/19 07:08:58] seafile-controller.c(94): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /mnt/D/Documents/seafile/conf/seafevents.conf --logfile /mnt/D/Documents/seafile/logs/seafevents.log -P /mnt/D/Documents/seafile/pids/seafevents.pid
[07/18/19 07:08:58] seafile-controller.c(109): spawned /usr/bin/python2.7, pid 3622
seafevents.log:
[2019-07-18 07:10:34,381] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:34,833] [INFO] audit is not enabled
[2019-07-18 07:10:34,845] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:34,872] [INFO] [seafevents] database: mysql, name: seafile-db
[2019-07-18 07:10:36,853] [INFO] The file with the following suffix will be recorded into the file history: md,txt,doc,docx,xls,xlsx,ppt,pptx
[2019-07-18 07:10:36,861] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:36,866] [INFO] Events publish to redis is disabled.
[2019-07-18 07:10:36,876] [INFO] LDAP section is not set, disable ldap sync.
[2019-07-18 07:10:36,880] [INFO] [virus_scan] scan_command option is not found in /mnt/D/Documents/seafile/conf/seafile.conf, disable virus scan.
[2019-07-18 07:10:36,894] [INFO] try to connect to ccnet-server…
[2019-07-18 07:10:36,896] [INFO] connected to ccnet server
[2019-07-18 07:10:36,908] [ERROR] Another instance is already running
File “/mnt/D/Documents/seafile/seafile-pro-server-7.0.4/pro/python/seafevents/app/app.py”, line 79, in connect_ccnet
self._sync_client.register_service_sync(‘seafevents-events-dummy-service’, ‘rpc-inner’)
File “/mnt/D/Documents/seafile/seafile-pro-server-7.0.4/seafile/lib64/python2.7/site-packages/ccnet/sync_client.py”, line 94, in register_service_sync
self.send_cmd(cmd)
File “/mnt/D/Documents/seafile/seafile-pro-server-7.0.4/seafile/lib64/python2.7/site-packages/ccnet/sync_client.py”, line 49, in send_cmd
raise RuntimeError(‘Failed to send-cmd: %s %s’ % (resp.code, resp.code_msg))
RuntimeError: Failed to send-cmd: 516 The service existed
[2019-07-18 07:10:36,912] [INFO] exit with code 1
[2019-07-18 07:10:44,094] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:44,456] [INFO] audit is not enabled
[2019-07-18 07:10:44,465] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:44,480] [INFO] [seafevents] database: mysql, name: seafile-db
[2019-07-18 07:10:46,118] [INFO] The file with the following suffix will be recorded into the file history: md,txt,doc,docx,xls,xlsx,ppt,pptx
[2019-07-18 07:10:46,125] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:46,130] [INFO] Events publish to redis is disabled.
[2019-07-18 07:10:46,141] [INFO] LDAP section is not set, disable ldap sync.
[2019-07-18 07:10:46,144] [INFO] [virus_scan] scan_command option is not found in /mnt/D/Documents/seafile/conf/seafile.conf, disable virus scan.
[2019-07-18 07:10:46,158] [INFO] try to connect to ccnet-server…
[2019-07-18 07:10:46,159] [INFO] connected to ccnet server
[2019-07-18 07:10:46,168] [ERROR] Another instance is already running
self.send_cmd(cmd)
[2019-07-18 07:10:46,172] [INFO] exit with code 1
[2019-07-18 07:10:53,536] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:53,929] [INFO] audit is not enabled
[2019-07-18 07:10:53,939] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:53,953] [INFO] [seafevents] database: mysql, name: seafile-db
[2019-07-18 07:10:55,542] [INFO] The file with the following suffix will be recorded into the file history: md,txt,doc,docx,xls,xlsx,ppt,pptx
[2019-07-18 07:10:55,547] [INFO] [seafevents] database: mysql, name: seahub-db
[2019-07-18 07:10:55,550] [INFO] Events publish to redis is disabled.
[2019-07-18 07:10:55,560] [INFO] LDAP section is not set, disable ldap sync.
[2019-07-18 07:10:55,563] [INFO] [virus_scan] scan_command option is not found in /mnt/D/Documents/seafile/conf/seafile.conf, disable virus scan.
[2019-07-18 07:10:55,573] [INFO] try to connect to ccnet-server…
[2019-07-18 07:10:55,574] [INFO] connected to ccnet server
[2019-07-18 07:10:55,579] [ERROR] Another instance is already running
self.send_cmd(cmd)
[2019-07-18 07:10:55,581] [INFO] exit with code 1
ccnet.log:
[07/18/19 07:11:43] …/common/peer.c(950): Local peer down
[07/18/19 07:11:53] …/common/session.c(409): Accepted a local client
[07/18/19 07:11:53] …/common/peer.c(950): Local peer down
[07/18/19 07:12:03] …/common/session.c(409): Accepted a local client
[07/18/19 07:12:03] …/common/peer.c(950): Local peer down
[07/18/19 07:12:13] …/common/session.c(409): Accepted a local client
[07/18/19 07:12:13] …/common/peer.c(950): Local peer down
[07/18/19 07:12:23] …/common/session.c(409): Accepted a local client
[07/18/19 07:12:23] …/common/peer.c(950): Local peer down
[07/18/19 07:12:33] …/common/session.c(409): Accepted a local client
[07/18/19 07:12:33] …/common/peer.c(950): Local peer down
[07/18/19 07:12:44] …/common/session.c(409): Accepted a local client
[07/18/19 07:12:44] …/common/peer.c(950): Local peer down
[07/18/19 07:12:53] …/common/session.c(409): Accepted a local client
[07/18/19 07:12:53] …/common/peer.c(950): Local peer down
[07/18/19 07:13:03] …/common/session.c(409): Accepted a local client
[07/18/19 07:13:03] …/common/peer.c(950): Local peer down
Configs:
ccnet.conf:
[General] USER_NAME = SweetHome ID = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx NAME = SweetHome SERVICE_URL = https://xxxxx.yyyyy.zzzzz [Client] PORT = 13419 [Database] ENGINE = mysql HOST = 127.0.0.1 PORT = 3306 USER = seafile PASSWD = seafile DB = ccnet-db CONNECTION_CHARSET = utf8
seafile.conf
[fileserver] port = 8082 # bind address for fileserver # default to 0.0.0.0, if deployed without proxy: no access restriction # set to 127.0.0.1, if used with local proxy: only access by local host = 127.0.0.1 [database] type = mysql host = 127.0.0.1 port = 3306 user = seafile password = seafile db_name = seafile-db connection_charset = utf8
seafevents.conf
[DATABASE] type = mysql host = 127.0.0.1 port = 3306 username = seafile password = seafile name = seahub-db [Audit] enabled = false [STATISTICS] ## must be "true" to enable statistics enabled = false [INDEX FILES] enabled = false interval = 10m ## If true, indexes the contents of office/pdf files while updating search index ## Note: If you change this option from "false" to "true", then you need to clear the search index and update the index again. See the FAQ for details. index_office_pdf = false [OFFICE CONVERTER] ## must be "true" to enable office/pdf online preview #enabled = true ## how many libreoffice worker processes should run concurrenlty #workers = 1 ## where to store the converted office/pdf files. Deafult is /tmp/. #outputdir = /tmp/ [SEAHUB EMAIL] enabled = true ## interval of sending Seahub email. Can be s(seconds), m(minutes), h(hours), d(days) interval = 30m
/etc/systemd/system/seafile.service
[Unit] Description=Seafile # add mysql.service or postgresql.service depending on your database to the line below After=network.target mariadb.service [Service] Type=forking ExecStart=/mnt/D/Documents/seafile/seafile-server-latest/seafile.sh start ExecStop=/mnt/D/Documents/seafile/seafile-server-latest/seafile.sh stop #RemainAfterExit=yes User=seafile Group=seafile [Install] WantedBy=multi-user.target
