Seafhttp does not work with Reverse Proxy
we want to use Seafile with our reverse proxy. We are forwarding all requests on / to Seafile, and /seafhttp to 127.0.0.1:8082, the /media location to the /media path in our seafile folder.
The webinterface works pretty well, however everything located below the /seafhttp path does not work and always return 404 (e.g. /seafhttp/protocol-version returns 404).
I think this has something to do with a missing rewrite - can we change the Path of seafhttp in the configuration so we do not need to rewrite it on our proxy?
/seafhttp cannot be changed.
Thanks for your reply!
If we cannot change the path, which rewrite rules should be set to get /seafhttp working? Simply forwarding it with the whole domain and the path does not work and results in 404 (as written above).
What’s your reverse proxy?
Personally, I tried Nginx but gave up and switched to Caddy, which I found much more intuitive. Here’s my Caddyfile entry for Seafile:
drive.example.com {
        tls my@email.com
        proxy / localhost:8000 {
                transparent
                websocket
        proxy /seafhttp localhost:8082 {
                transparent
                without /seafhttp
It works perfectly for me with that setup.
I am also using Caddy, the without /seafhttp solved the Problem!
Thank you very much :slight_smile:
