Seafile 6.0.5 no HTTPS response
yesterday i´ve set up a 6.0.5 server on a raspberry pi 3 (mysql, nginx, https (self created cert)). For some reason i don´t get access to the service. With Chrome i get a “ERR_CONNECTION_CLOSED” message.
Here´s my nginx config located in /etc/nginx/sites-available/seafile.conf:
    listen 80;
    server_name #removed;
    listen 443;
    ssl on;
    ssl_certificate /etc/nginx/ssl/cacert.pem;
    ssl_certificate_key /etc/nginx/ssl/privkey.pem;
    server_tokens off;
        fastcgi_param    SERVER_PROTOCOL        $server_protocol;
        fastcgi_param    SERVER_ADDR         $server_addr;
        fastcgi_param    SERVER_PORT         $server_port;
        fastcgi_param    SERVER_NAME         $server_name;
        fastcgi_param   HTTPS           on;
        fastcgi_param   HTTP_SCHEME     https;
        fastcgi_read_timeout 36000;
        proxy_read_timeout  36000s;
        proxy_send_timeout  36000s;
        root /mnt/pidrive/seafile/seafile-server-latest/seahub;
What´s wrong? Any ideas? Do you need addtional config files/logs?
I am having ERR_CONNECTION_CLOSED problem in my PC
Your configuration contains:
ssl_certificate should refer to a server certificate, NOT a root CA certificate. It looks like you are using the wrong certificate type, looking at the name cacert.pem. Use the CA certificate to sign a server certificate instead, and use this server certificate in nginx. If you have intermediate CA certificates, it is a good idea to append them to the PEM file used by nginx. See Module ngx_http_ssl_module
