Hello
I have Seafile Pro deployed under subdomain.domain
And Collabora online on another machine deployed under othersubdomain.domain
I have the following error from the seahub.log while trying to open docs from seafile:
[ERROR] seahub.wopi.utils:108 get_wopi_dict mismatched tag: line 16, column 2
Here is my seahub_settings.py:
# -*- coding: utf-8 -*-
SECRET_KEY = "*secretkey*"
FILE_SERVER_ROOT = 'http://*subdomain*.*domain*/seafhttp'
DATABASES = {
'default': {
'NAME': 'seahub_db',
'USER': '*myuser*',
'PASSWORD': '*mypassword*',
'HOST': '127.0.0.1',
'PORT': '3306'
CACHES = {
'default': {
# 'BACKEND': 'django_pylibmc.memcached.PyLibMCCache',
'BACKEND': 'django.core.cache.backends.memcached.MemcachedCache',
'LOCATION': '127.0.0.1:11211',
'locmem': {
# Attempt limit before showing a captcha when login.
LOGIN_ATTEMPT_LIMIT = 3
# From 6.1.0 CE version on, Seafile support viewing/editing **doc**, **ppt**, **xls** files via LibreOffice
# Add this setting to view/edit **doc**, **ppt**, **xls** files
# Enable LibreOffice Online
ENABLE_OFFICE_WEB_APP = True
# Url of LibreOffice Online's discovery page
# The discovery page tells Seafile how to interact with LibreOffice Online when view file online
# You should change `https://collabora-online.seafile.com/hosting/discovery` to your actual LibreOffice Online server address
OFFICE_WEB_APP_BASE_URL = 'https://*othersubdomain*.*domain*'
# Expiration of WOPI access token
# WOPI access token is a string used by Seafile to determine the file's
# identity and permissions when use LibreOffice Online view it online
# And for security reason, this token should expire after a set time period
WOPI_ACCESS_TOKEN_EXPIRATION = 30 * 60 # seconds
# List of file formats that you want to view through LibreOffice Online
# You can change this value according to your preferences
# And of course you should make sure your LibreOffice Online supports to preview
# the files with the specified extensions
OFFICE_WEB_APP_FILE_EXTENSION = ('odp', 'ods', 'odt', 'xls', 'xlsb', 'xlsm', 'xlsx','ppsx', 'ppt', 'pptm', 'pptx', 'doc', 'docm', 'docx')
# Enable edit files through LibreOffice Online
# types of files should be editable through LibreOffice Online
OFFICE_WEB_APP_EDIT_FILE_EXTENSION = ('odp', 'ods', 'odt', 'xls', 'xlsb', 'xlsm', 'xlsx','ppsx', 'ppt', 'pptm', 'pptx', 'doc', 'docm', 'docx')
Anyone have an idea how to get rid of this error?
P.S. Values with italic font and these inside … are substituted for privacy reasons.
