Hey there,
i cannot upgrade my seafile pro docker install from 7.0.13 to 7.1.7. I use docker compose and it runs fine with 7.0.13 since the day of the old release. However i am not able to upgrade to any 7.1.x release.
This are the actual logs directly after booting up the container:
** Message: 21:55:48.750: seafile-controller.c(1009): loading seafdav config from /opt/seafile/conf/seafdav.conf,
Seafile server started,
Done.,
Starting seahub at port 8000 ...,
Error:Seahub failed to start.,
Please try to run "./seahub.sh start" again,
[2020-10-10 21:55:48] Preparing for letsencrypt ...,
[2020-10-10 21:55:48] Found existing cert file /shared/ssl/sslcert.com.crt,
[2020-10-10 21:55:48] Skip letsencrypt verification since we have a valid certificate,
[2020-10-10 21:55:48] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.,
Traceback (most recent call last):,
File "/scripts/start.py", line 86, in <module>,
main(),
File "/scripts/start.py", line 72, in main,
call('{} start'.format(get_script('seahub.sh'))),
File "/scripts/utils/__init__.py", line 70, in call,
return subprocess.check_call(*a, **kw),
File "/usr/lib/python3.6/subprocess.py", line 311, in check_call,
raise CalledProcessError(retcode, cmd),
subprocess.CalledProcessError: Command '/opt/seafile/seafile-pro-server-7.1.7/seahub.sh start' returned non-zero exit status 1.,
*** /scripts/start.py exited with status 1.,
*** Shutting down runit daemon (PID 23)...,
*** Running /etc/my_init.post_shutdown.d/10_syslog-ng.shutdown...,
*** Killing all processes...,
*** Running /etc/my_init.d/01_create_data_links.sh...,
rm: cannot remove '/var/log/nginx': Device or resource busy,
*** Booting runit daemon...,
*** Runit started as PID 23,
*** Running /scripts/start.py...,
Certificate will not expire,
Found existing the script for renew the cert.,
Skip create the crontab for letscncrypt since maybe we have created before.,
[10/10/2020 21:56:24][upgrade]: The container was recreated, running minor-upgrade.sh to fix the media symlinks,
[10/10/2020 21:56:24][upgrade]: Running script /opt/seafile/seafile-pro-server-7.1.7/upgrade/minor-upgrade.sh,
This script would do the minor upgrade for you.,
Press [ENTER] to contiune,
renaming the gunicorn.conf to gunicorn.conf.py ...,
Done,
migrating avatars ...,
DONE,
Moving the elasticsearch's configuration file ...,
/bin/cp: '/opt/seafile/seafile-server-latest/pro/elasticsearch/config/jvm.options' and '/opt/seafile/seafile-pro-server-7.1.7/pro/elasticsearch/config/jvm.options' are the same file,
updating seafile-server-latest symbolic link to /opt/seafile/seafile-pro-server-7.1.7 ...,
DONE,
** Message: 21:56:24.547: seafile-controller.c(1009): loading seafdav config from /opt/seafile/conf/seafdav.conf,
[10/10/20 21:56:24] ../common/session.c(156): using config file /opt/seafile/conf/ccnet.conf,
[10/10/20 21:56:24] ../common/license.c(427): Loading license file /opt/seafile/seafile-license.txt ..,
[10/10/20 21:56:24] ../common/license.c(430): License file /opt/seafile/seafile-license.txt does not exist, allow at most 3 trial users,
Starting seafile server, please wait ...,
** Message: 21:56:24.577: seafile-controller.c(1009): loading seafdav config from /opt/seafile/conf/seafdav.conf,
Done.,
[2020-10-10 21:56:24] Preparing for letsencrypt ...,
[2020-10-10 21:56:24] Found existing cert file /shared/ssl/sslcert.com.crt.crt,
[2020-10-10 21:56:24] Skip letsencrypt verification since we have a valid certificate,
[2020-10-10 21:56:24] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.,
main(),
and from there its a reboot loop all the time.
This is the docker compose file:
version: '2'
db:
image: mariadb:10.1
container_name: seafile-mysql
- "3306:3306"
- MYSQL_ROOT_PASSWORD=xxxx # Requested, set the root's password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- /opt/seafile/db:/var/lib/mysql
- /opt/seafile/dblogs:/var/log
- /xxxx/seafile_data:/shared
networks:
- seafile-net
restart: unless-stopped
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seafile-net
elasticsearch:
image: seafileltd/elasticsearch-with-ik:5.6.16
- discovery.type=single-node
- bootstrap.memory_lock=true
- "ES_JAVA_OPTS=-Xms1g -Xmx1g"
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 2g
#- /opt/seafile-elasticsearch/data:/usr/share/elasticsearch/data # Requested, specifies the path to Elasticsearch data persistent store.
- /xxxx/seafile_data/elasticsearch/data:/usr/share/elasticsearch/data # Requested, specifies the path to Elasticsearch data persistent store.
- /opt/seafile/logs:/opt/seafile/logs
#- /opt/seafile/logs:/shared/seafile/logs
- /opt/seafile/logs_var:/var/log
networks:
- seafile-net
seafile:
#image: docker.seadrive.org/seafileltd/seafile-pro-mc:7.0.13
image: docker.seadrive.org/seafileltd/seafile-pro-mc:latest
- "80:80"
- "443:443" # If https is enabled, cancel the comment.
- "8081:8080"
- "8082:8000"
- "8083:8082"
- /xxxx/seafile_data:/shared # Requested, specifies the path to Seafile data persistent store.
- /opt/seafile/logs_var/nginx:/var/log/nginx
- DB_HOST=db
- DB_ROOT_PASSWD=xxxx
- TZ=Europe/Vienna
- SEAFILE_SERVER_LETSENCRYPT=true
- SEAFILE_SERVER_HOSTNAME=xxx.com
- SEAFILE_ADMIN_EMAIL=xxx@ccc.com
- SEAFILE_ADMIN_PASSWORD=xxx
- VIRTUAL_HOST=xxx
- LETSENCRYPT_HOST=xxx
- LETSENCRYPT_EMAIL=xxxx
depends_on:
- db
- memcached
- elasticsearch
networks:
- seafile-net
networks:
seafile-net:
This issue is already pretty annoying because i have to stay on 7.0.13 for the foreseeable future.
Hope anyone can help me!
With best regards and thanks in advance
satheras
