Seafile 8.0.x with WebDav and 2FA
I’m running the latest 8 version of Seafile in the official Docker container. I have enabled both 2FA and webdav. I can use webdav for one user without an issue, for which 2FA is not enabled. For another user with 2FA enabled, the request always returns 401 Access not authorized.
Does anybody know what the official status of webdav, API tokens and 2FA is? It may be correct to disable webdav if it does not implement 2FA correctly. Ideally, I could configure webdav access on a per-library level using API tokens.
