Uh⌠3 pages of errors. But the first one is as follow:
[ERROR] seafes:92 get_repo_name_mtime_size: âResultProxyâ object has no attribute âmappingsâ
which then repeats few times:
AttributeError: âResultProxyâ object has no attribute âmappingsâ
and then again the same error few times.
The reports show than 16 commit read, 0 dir read, 0 file read, 0 block read
To more specify the error: It happens in init.py execution as such:
File âopt/seafile/seafile-pro-server-9.0.2/pro/python/seafes/repo_data/init.pyâ, line 16, in to_dict
for i in result_proxy.mappings():
I had the same Problem ⌠Elasticsearch exists after a few secounds in the Docker version. Is there a way to get LogFiles from Elasticsearch with the reason for the Exit ?
See the other thread on this with the solution:
âI installed ALL pip requirements in both users, root and seafile. This helped and is now working.â
