Seafile and Nuxeo
In our company the IT department runs a Seafile environment with a Ceph backend. We have all our stuff in there. But sometimes particular files are hard to find in a bunch of folders. So we got the idea to run a digital assets management server (i.e. Nuxeo) and to use Seafile as storage. I’m not sure how to connect these things together. Hope to find some answers here or maybe someone else had the same idea or a better one.
Thanks
If you run the PRO Version you have Search available. This should help to find files and folders. :slight_smile:
Maybe they do have WebDAV Support.
Otherwise if read only is enough, you could mount Seafile using FUSE.
https://manual.seafile.com/extension/
