Dear All,
I’m planing running a seafile server at home. At the moment I’m thinking about how I want to publish it to the internet. Dispite all the DNS stuff I have to solve, this topic is about the Firewall.
Normaly I dont expose the Webserver directly towards the internet, instead I place a reverse Proxy infront if it.
As im not sure if I want to buy a APU and setup PFsense (to have the possibility to install HTTPS Proxy on the Firewall) or if I just use the Fritzbox and do a portforwarding.
If the NGINX Server is recommended and enough to secure the Seafile Services as a Proxy properly, I would be fine with a normal Portforwarding. But I’m not sure if the NGINX acts as a Proxy or just as a normal Webserver for seafile
So to bring my question in to one sentence: Is the NGINX instance a state of the art security solution for a seafile server or is the proper way to secure a seafile server to put a seperated HTTPS-Proxy infront of the NGINX that itself is infront of the SeafileServer or I’m I fine with just NGINX and Seafile on one mashine and having ports forwarded?
Thanks for your advice and with kind regards,
Michael
