I plan to install Seafile CE in a docker container and to integrate it with Collabora Online on the same host. Sadly the binary images will be deprecated soon. I will have nginx as a reverse proxy for both Seafile and Collabora containers. My question is, what ports should I have open on my router for it to work? Just 80, 443, 10001, 12001, 8080 or I will need to another one?
You should only have port 443 open on your router for your reverse proxy. The reverse proxy will then use some of those other ports you mentioned to talk to seafile, but that’s all happening behind the router, so it doesn’t need ports opened.
