Seafile Client failes to autostart on Kubuntu 22.04
Hi there, I’m running Kubuntu 22.04, and i found seafile client on the discover app. I tried installing it, and adding it to autostart. However instead of starting up, it pops up two dialog boxes stating “Seafile Client is already running” and then it fails to start at all.
So i uninstalled then followed the official directions listed here: Install On Linux - Seafile User Manual
I added the apt ppa, and installed Seafile-Gui and… same issue. but if i remove seafile-client from the autostart in settings, it still dosnt start on startup.
What’s causing it to start twice? this is only a problem with seafile.
