Seafile client (ubuntu) takes (too) many INotify watchers
I was running into a problem that I could no longer open some tools such as VS Code. I ran a script found on https://github.com/fatso83/dotfiles/blob/master/utils/scripts/inotify-consumers
the result:
Inotify watches count | instances per process | PID | User | COMMAND
36871 | 2 | 322291 | user | /usr/bin/seaf-daemon -c /home/user/.ccnet -d /home/user/Seafile/.seafile-data -w /home/user/Seafile
When I quit seafile client I can open vs code and then I can start seafile client again. From then on everything works fine except that when I run the script again, still seafile comes up with many watchers.
What can I do?
bumping since I still have this issue and I’m not sure what to do about it.
Have you tried increasing the inotify limit?
