Seafile Client: Warn when storing library on shared filesystem
Hi all,
we want to propose a feature in the Seafile Client (possibly configurable on the server like DISABLE_SYNC_WITH_ANY_FOLDER) that warns users when they want to sync a library that is stored on a shared filesystem (e.g. NFS or a Windows Network Drive).
See also Uploading large files to *one* library fails for one possible problem when doing so ;-).
Best wishes,
Moritz
I second this feature request.
Recently a group of my customers reported massive problems syncing libraries, but only a few computers were affected. But instead of asking me for help directly, the tried to circumvent the problem by using other programs because »Seafile is unreliable« (cited literally).
After I come to know the problem, it was easy to solve: After moving the Seafile base folder to a local drive all problems vanished. But I fear that there might be more users with similar problems, that will not contact me and abandon using Seafile at all.
A check during installation if the Seafile base folder is located on a local drive and at least an explicit warning would prevent this. But perhaps it would be even better, that the client would refuse to use a base folder on shared drives.
Best regards,
Thomas
Thanks for the suggestion. I think the problem only presents on Linux. We’ve already have this check on Windows. We’ll add this to our next release.
That’s great, thanks!
