FIXED by this
python3 -m pip install --force-reinstall --upgrade --target /opt/seafile/seafile-pro-server-9.0.13/seahub/thirdpart cffi==1.14.6
FIXED by this
Hi Iām trying to get the seafile up and running after server migration from 18.x to 22.04 (on linux mint 21.1). So I have the same problem with the lib with server version 9.0.10.
Iām not sure about the rest of the configuration (like apache2) but as for now after applying the 14.6.0 library forced install my seahub is still not starting? At least it is not working as expected (Internal Server Error on webpage request). Seahub.sh start-fastcgi gives in response:
Starting seahub (fastcgi) at 127.0.0.1:8000 ...
Warning: File comment has changed since version 6.3, while table `base_filecomment` is not migrated yet, please consider migrate it according to v6.3.0 release note, otherwise the file comment feature will not work correctly.
Unknown command: 'runfcgi'
Type 'manage.py help' for usage.Error:
Seahub failed to start.
Normal start runs but I got Internal Server Error on webpage launch. The seagub.log produces nothing.
Any advice? Thanks!
seeing similar to the above error - bumping topic
