I did look in the manual and I did found out that the host as default is 0.0.0.0 and I just want to make sure that I do understand it correctly.
If your running it with local proxy (nginx or apache2) then you should change that to host = 127.0.0.1 to restrict access?
But I guess that my firewall should also block any attack against it aswell as I guess it’s over port 8082? And I have only port 80 and 443 opened.
But if it’s increasing the security I guess that I could change it, better safe then sorry I guess.
