Seafile Docker configuration
Is it possible to setup LDAP and database settings (to be sqlite/postgresql instead of mysql or to be on a different port than default one) from docker-compose file or the only way to do this is to modify configuration files? I’ve been searching for hours but everything I found is docs and it is not enough :confused:
Is it possible to create something like list with all properties, which can be set via docker environment?
