Seafile don't start after reboot
#1
I followed this guide https://manual.seafile.com/deploy/start_seafile_at_system_bootup.html but after server reboot the seafile don’t start.
My server running centos 6 x64
What did I do…
Step 1. Create a file /etc/sysconfig/seafile
Change the value of “user” to your linux user name
user=root
Change the value of “seafile_dir” to your path of seafile installation
usually the home directory of $user
seafile_dir=/root/haiwen
script_path=${seafile_dir}/seafile-server-latest
seafile_init_log=${seafile_dir}/logs/seafile.init.log
seahub_init_log=${seafile_dir}/logs/seahub.init.log
Change the value of fastcgi to true if fastcgi is to be used
fastcgi=true
Set the port of fastcgi, default is 8000. Change it if you need different.
fastcgi_port=8000
Step 2. Create a script /etc/rc.d/init.d/seafile
#!/bin/bash
seafile
chkconfig: - 68 32
description: seafile
Source function library.
. /etc/init.d/functions
Source networking configuration.
. /etc/sysconfig/network
if [ -f /etc/sysconfig/seafile ];then
. /etc/sysconfig/seafile
else
echo “Config file /etc/sysconfig/seafile not found! Bye.”
exit 200
fi
RETVAL=0
start() {
# Start daemons.
echo -n $“Starting seafile: "
ulimit -n 30000
su - ${user} -c”${script_path}/seafile.sh start >> ${seafile_init_log} 2>&1"
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && touch /var/lock/subsys/seafile
return $RETVAL
stop() {
echo -n $“Shutting down seafile: "
su - ${user} -c”${script_path}/seafile.sh stop >> ${seafile_init_log} 2>&1"
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/seafile
return $RETVAL
Write a polite log message with date and time
echo -e "\n \n About to perform $1 for seafile at date -Iseconds \n " >> ${seafile_init_log}
See how we were called.
case “$1” in
start)
start
stop)
stop
restart|reload)
stop
start
RETVAL=$?
echo $“Usage: $0 {start|stop|restart}”
RETVAL=3
esac
exit $RETVAL
Step 3. Create a script /etc/rc.d/init.d/seahub
#!/bin/bash
seahub
chkconfig: - 69 31
description: seahub
else
exit 200
fi
RETVAL=0
start() {
# Start daemons.
echo -n $“Starting seahub: "
ulimit -n 30000
if [ $fastcgi = true ];
then
su - ${user} -c”${script_path}/seahub.sh start-fastcgi ${fastcgi_port} >> ${seahub_init_log} 2>&1"
else
su - ${user} -c"${script_path}/seahub.sh start >> ${seahub_init_log} 2>&1"
fi
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && touch /var/lock/subsys/seahub
return $RETVAL
stop() {
echo -n $“Shutting down seahub: "
su - ${user} -c”${script_path}/seahub.sh stop >> ${seahub_init_log} 2>&1"
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/seahub
return $RETVAL
echo -e "\n \n About to perform $1 for seahub at date -Iseconds \n " >> ${seahub_init_log}
case “$1” in
start)
start
stop)
stop
restart|reload)
stop
start
RETVAL=$?
RETVAL=3
esac
exit $RETVAL
The seafile path is /root/haiwen
I have to do something else?
Regards,
#2
What error do you receive when you try to start it manually?
#3
I noticed you set fastcgi to true. Do you have Seafile configured for fastcgi? If you use NGinx or Apache, are they configured for fastcgi? Fastcgi is deprecated, though it still works. WSGI is the recommended way to run seafile now.
#4
I haven’t any error, start manually the seafile started
#5
The fastcgi to true is my mistake, i change this tto off but nothing happens…
#6
Are you still trying with systemd or are you now trying with init.d? If init.d, after you made the most recent changes, did you issue this command?
sudo update-rc.d seafile-server defaults
#7
Just realized you are using CENTOS… Hold on a minute… looking at the manual.
#8
Can you repost your startup file here since you’ve changed it from fastcgi? What commands are you running that start it manually, successfully.
#9
I’m seeing several things that could be the issue. Questions for you…
  • What user name do you use when you log into a terminal that successfully starts Seafile?
  • What commands are you using that successfully start Seafile?
  • What is the path of the folder where Seafile is installed?
#10
  1. What user name do you use when you log into a terminal that successfully starts Seafile?
    root
    2.What commands are you using that successfully start Seafile?
    cd haiwen
    cd seafile-server-*
    ./seafile.sh start
    ./seahub.sh start 8000
    3.What is the path of the folder where Seafile is installed?
#11
Can you check those two log files to see what’s in there? They may provide a clue since they are the files referenced in the script.
#12
Seagile log
[05/16/2018 04:54:40 PM] …/common/mq-mgr.c(54): [mq client] mq cilent is started
[05/16/2018 04:54:41 PM] size-sched.c(96): Repo size compute queue size is 0
[05/17/2018 12:10:58 PM] size-sched.c(96): Repo size compute queue size is 0
[05/17/2018 12:15:58 PM] size-sched.c(96): Repo size compute queue size is 0
[05/17/2018 12:20:58 PM] size-sched.c(96): Repo size compute queue size is 0
[05/17/2018 12:25:58 PM] size-sched.c(96): Repo size compute queue size is 0
[05/17/2018 12:30:58 PM] size-sched.c(96): Repo size compute queue size is 0
[05/17/2018 12:35:58 PM] size-sched.c(96): Repo size compute queue size is 0
Seahub log
2018-05-16 09:51:36,100 [WARNING] seahub.auth.views:144 login Login attempt limit reached, show Captcha, email/username: *****@hotmail.com, ip: 46.246.., attemps: 5
Nothing else…
#13
Can you take a look at your system log? Let’s see if there is any indication in there.
