Seafile Drive not loading under MacOS Sonoma 14.0
Hi everyone!
I am using the SeaDrive with my Your Secure Cloud - Login. Everything is fine so far… Today I updated my MacOS to Sonoma 14.0 - the client can not started. The problem:
“Failed to initialize: failed to install kernel driver”
I checked all security preferences. What can I do? The root permission is on low security with both checks and I allow apps from third sources. But no result.
Please help me. I need the Drive.
Thank you!
Peter
Im having the same issue too.
Hi Both,
Have you tried re-installing the Drive Client/Seafile application since updating?
Apple has a habit of messing around with root files and kernels during updates which can cause issues with installations.
Kind regards,
Mitch
Hi there. Now everthing is fine. I deleted all applications and re-installed it with the newest version - first die application from yoursecurecloud and afterwards the SeaDrive-Client.
It works now!
