Seafile-ignore does not work
In the root folder of my library, I included a file “seafile-ignore.txt”.
In that file, I put “/home/USERNAME/Documents/src/”
After deleting and recreating the src folder, seafile syncs it again.
I think you can only put paths relative to the library root in there.
So if Documents is your library, it would be sufficient to put only src in seafile-ignore.txt
Thanks! That was indeed the problem. Where can I suggest the devs to put this detail about relative paths more clearly on their web site? https://www.seafile.com/en/help/ignore/
