Seafile.ini in ccnet
I just upgraded my server and when trying to run the ./seafile.sh I get an error seafile.ini not found. Can someone please explain to mean how to navigate around this error. I have checked for a solution online, most people say that I should create a simulink to where I want to store the data. I am not sure, should the link be to a file or folder? what should I do after creating the link?
What version do you use? seafile.ini should have not been used for a long time.
In case you need seafile.ini, just create it under ccnet/seafile.ini. The file should contain a line with the absolute path of the folder seafile-data in your system.
Do you have any other messages? Anything from the seafile logs?
