Seafile is running fine but noch reachable within LAN
Hey there.
I am runnning a Seafile server. The logs don’t throw any error and the shell says:
[10/30/17 19:37:42] ../common/session.c(132): using config file /home/seafile/conf/ccnet.conf
Seafile server started
Done.
Seahub is not running
/home/seafile/seafile-server-latest/seahub.sh: Zeile 209: Warnung: setlocale: LC_ALL: Kann die Locale nicht ändern (en_US.UTF-8): Datei oder Verzeichnis nicht gefunden
Starting seahub (fastcgi) at 127.0.0.1:8000 ...
Seahub is started
Done.
In ccnet.conf I set
SERVICE_URL = http://192.168.0.10:8000
But when I try to access http://192.168.0.10:8000, I get a time out in my browser.
The device is connected via LAN cable. When I scan the ports from another computer (also connected with LAN cable) with nmap the result says that port 8000 is closed. Although port 8082 is open. My IPTABLES are:
-A INPUT -s 192.168.0.0/24 -p tcp -m state --state NEW -m tcp --dport 8000 -j ACCEPT
-A INPUT -s 192.168.0.0/24 -p tcp -m state --state NEW -m tcp --dport 8082 -j ACCEPT
So to me it looks like nmap says the port is closed, because the application is not running. But according to the logs it is running.
What am I not seing here? Any help is appriciated!
Regards
bob
Hmm,
first of all try to delete/flush your iptables “sudo iptables -F” then look what “sudo netstat -naptl” says. Is port 8000 / 8082 listening on 0.0.0.0 or 192.168.0.10 or in contrast to the SERVICE_URL setting only on localhost?
It’s running as localhost, not as 192.168.0.10:8000. Maybe this is the problem?
But if, what can I do, I already set the service URL to 192.168.0.10:8000
tcp 0 0 127.0.0.1:8000 0.0.0.0:* LISTEN 20030/python2.7
Oh and if I flush the rules, could this lock me out of the system permanently?
BTW. Did you try to restart seafile and seahub? :smiley:
sure, several times.
where is you cent.conf located? Here /home/seafile/conf/ccnet.conf
perhaps your config isn’t loaded while starting the service…
that’s the location: “/home/seafile/conf/ccnet.conf”
Is there another config that sets the SERVICE_URL?
look good. As far as I know you can overwrite the URL in the Admin Backend.
Login in the GUI and got to “admin panel” goto “settings” there you can overwrite the URL.
perhaps this helps
I would love to do that, but first I need so access it succesfully :slight_smile:
Today I completely reinstalled Seafile but the problems persists.
I also flushed the iptables rules. nmap then said the port is filtered and not closed any more.
