Hey I installed Seafile Server Pro on my debian and when I try to run ./pro/pro.py virus_scan output is: No module named parse
I use clamav (clamd). Can give me advice someone? Where is the issue?
just a guess as I’m not using the pro server / virus scan.
The error says “no module named parse”, i.e., python cannot find the module.
It looks like parse is part of the urllib python module.
Maybe you can try installing the package.
Again, just a guess. Good luck
Hi
Which package do you mean? Do you mean reinstall whole seafile server?
I meant the python3-urllib3 debian package
((sudo) apt-get install python3-urllib3)
This is because they have strangely limited search for Python 3 executables in get_python_executable() function (lines 288-304) in pro.py. There is only “python3.6” in the list (line 291). Recent Debian does not have python3.6, but it still has python2 as its default python interpreter:
root@server:~# ls -la /usr/bin/python
lrwxrwxrwx 1 root root 7 Mar 4 2019 /usr/bin/python -> python2
This means that searching for python3.6 fails and falls back to python
executable (line 291) - which is python2.
You can:
PYTHON=python3 ./pro/pro.py virus_scan
update-alternatives --config python
. Be careful, though - this could affect scripts and utilities which are not yet ported to Python 3try_list = [
'python3', 'python3.6'
But this gets overriden on each upgrade
