Seafile Pro 8.0.x: WebDAV unreachable every x days
Since I upgraded to Seafile Pro 8, every few days WebDAV seems to hang on a Ubuntu 20.4 installation until I restart the services. With the last 7.x version I didn’t have that problem. Seafile and Seahub (and nginx) are reportedly still operating properly, but after about a week, the seafdav URL cannot be reached anymore, until I restart services.
And yes, I changed the server block rules for the /seafdav directory when upgrading. Is this a known problem? Or something I can do to find out where the problem lies?
i use webdav with my Synology DiskStation to sync a Library. Seafile Server is Version 8.0.1.
So far, it works since 3 or 4 weeks.
Is there anything unusual in the logs of the Server?
I have no clue whether this is related, but I also see timeouts on WebDAV connections, which can be solved each time by “waking up” the Seafile server e.g. by loading a directory in the Seafile app. Would be great to see this fixed.
In fact, that’s what’s happening here as well. Apps that rely on my WebDAV timeout pretty quickly depending on their settings. If I point my browser to my-url.tld/seafdav it tries to connect and never reaches the server. Seafile client and general library syncing seem to work fine.
In what way exactly do you ‘wake up’ Seafile? Though a client, e.g. Windows or Mac, or your web interface?
When you say “…timeout pretty quickly” what do you mean?
Have you posted the timeout issue at Seafile’s Github yet?
When I say that I mean ‘the apps [developed by others that incorporate WebDAV usage] have a low timeout value and report back an error in a lot shorter time than my browser does when it tries to reach the WebDAV via /seafdav’ :grinning: .
I haven’t posted anything on Github, as I wanted to see if someone else has the same problem, or if there is a common solution to this, or my mistake by any chance.
The behaviour is as described, after a few days, WebDAV from my 8.0.x installation (since 8.0.1) cannot be reached anymore. If I try it via browser, it’s trying to connect and not timing out so quickly, but still not reaching the WebDAV implementation anymore. Third-party apps are quicker and report no connection a lot earlier, since they seem to have a lower threshold.
Are you saying that some apps timeout in 2-3 days or sooner? What’s the approximate time frame?
I don’t check all the time, I probably only realise it a bit after it happened, but last time it occurred, about seven days passed since the last Seafile restart to the timeouts.
The timeout problem on the server occurs after a few days, irregardless of any app’s timeout span (i.e. at which point an app gives up trying to connect when attempting to upload and/or download via WebDAV). Please disregard the mentions of the web interface vs. third-party app timeouts, that’s just irritating and not helping this case :slight_smile: .
Seafile’s WebDAV on my installation just wouldn’t connect anymore after a few days of running, until I manually re-start the services on my Ubuntu web server. I couldn’t find anything helpful in the logs, but I’ll try to see next time it happens if I can catch anything.
Just a little heads up: The timeout seems to occur pretty much every seven days, still cannot really say a 100% accurate, as I don’t always check if the WebDAV URL is still accessible. The Seafile-related error logs are all clean and dry.
What I do is a cronjob-based garbage collection every Sunday night, but I believe that’s not related to the breaking WebDAV connection, unfortunately.
Unfortunately, even after moving to a new server, with a fresh installation of Seafile Pro (now version 9) among all the part of my Ubuntu 22.04 installation (manual installation), this is still happening. Approximately once a week, I am forced to manually restart both the seafile and the seahub service to get WebDAV running again. I do believe it’s not always the same day on which this happens. Anyone got any idea what this could be?
