We’re using SeaFile Pro through docker, I’ve just updated our server version, it seems though that when I pull the latest docker image (docker. seadrive. org/seafileltd/seafile-pro-mc:latest), I get 7.1.14, I don’t get an 8.x version.
Is the 8.x version not yet available through docker?
If you check https://docker.seadrive.org, 7.1.14 is indeed the latest version of Pro. Perhaps someone from development can chime in on timing for a 8.x Pro docker version?
You can actually get 8.0.2 via docker but that is the latest – for some reason the most current builds are not available via docker. You are correct that the latest tag is attached to an older version so you have to specify manually:
If you want to check the latest versions available (since they are not tagged correctly), you can follow these steps:
Get your PRO docker username (seafile) and password from your customer hub portal
Go to https://docker.seadrive.org and login to the Harbor instance with the same credentials you use when downloading docker images (what you got in step 1)
Under projects, click on “seafileltd” then “seafileltd/seafile-pro-mc”
This will show a list of all tags for seafile pro, click twice on the ‘Tag’ heading to sort from newest-oldest
You will see the ‘latest’ tag and then ‘8.0.2’ right under that. Note the creation times – this is how you know ‘latest’ is NOT the latest.
Hope this helps, took me a while to find this. Really wish it was documented somewhere, but hopefully people see this post and find a little guidance.
