Do you also have problems installing the composer Seafile Pro 9? I used the docker-compose .yml from the manual site.
Docker fails to launch elasticsearch container.
version: ‘2.0’
db:
image: mariadb:10.5
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=db_dev # Requested, set the root’s password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- /opt/seafile-mysql/db:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seafile-net
elasticsearch:
image: elasticsearch:7.16.2
- discovery.type=single-node
- bootstrap.memory_lock=true
- “ES_JAVA_OPTS=-Xms1g -Xmx1g”
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 2g
- /opt/seafile-elasticsearch/data:/usr/share/elasticsearch/data # Requested, specifies the path to Elasticsearch data persistent store.
networks:
- seafile-net
seafile:
image: docker.seafile.top/seafileltd/seafile-pro-mc:latest
- “80:80”
- “443:443” # If https is enabled, cancel the comment.
- /opt/seafile-data:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD=db_dev # Requested, the value shuold be root's password of MySQL service.
- TIME_ZONE=Asia/Shanghai # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL=me@example.com # Specifies Seafile admin user, default is 'me@example.com'
- SEAFILE_ADMIN_PASSWORD=asecret # Specifies Seafile admin password, default is 'asecret'
- SEAFILE_SERVER_LETSENCRYPT=false # Whether to use https or not
- SEAFILE_SERVER_HOSTNAME=example.seafile.com # Specifies your host name if https is enabled
depends_on:
- db
- memcached
- elasticsearch
networks:
- seafile-net
networks:
seafile-net:
